Question about Sewing Machines
SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning
with the spool, guide the thread through the thread guides to the
tension assembly. Pull the thread through the tension assembly and test
it to make sure the tension is working correctly.
(To do this
test,adjust your tension setting to normal or medium or 5 or something
in the middle. Raise the presser foot and pull the thread through the
tension. It should pull easily!! Lower the presser foot and pull the
thread. It should pull noticeably harder.) If it passes this test,
continue up through the take up lever,then down through the thread
guides to the needle. Make sure your needle is fully inserted and
turned the correct way.( If you load your bobbin case from the left
side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are
some exceptions. If you have a newer style drop in bobbin or your
bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Posted on Jun 05, 2008
SOURCE: Kenmore sewing machine manual for model # 148 12080. (older)
i have a older kenmore sewing machine model #148.19370
Posted on Sep 17, 2008
go to www.sears.pammar.net for a few bucks he will send you the manual in a pdf. format
newbeginning1983@yahoo.com
Posted on Apr 04, 2009
SOURCE: Sewing machine Homemaker Everyday model HMFY-2300
Try this site manuals online , down load for free.
Posted on Jul 26, 2009
SOURCE: I need a manual for a Sears Kenmore sewing machine model 148.231
Try www.sewing-machine-manuals.com and click on relics and don't be put off by the word relics
Posted on Oct 24, 2009
Nov 20, 2017 | Kenmore Sewing Machines
Jan 03, 2017 | Kenmore Sewing Machines
Dec 16, 2015 | Kenmore Sewing Machines
Nov 22, 2015 | Kenmore Sewing Machines
Nov 13, 2015 | Sewing Machines
Oct 17, 2015 | Sewing Machines
Aug 04, 2012 | Sewing Machines
Nov 20, 2011 | Sewing Machines
Mar 25, 2011 | Kenmore Sewing Machines
Oct 21, 2009 | Kenmore Sewing Machines
