Question about Maytag Neptune MDE5500AY Electric Dryer
Dryer light comes on but nothing else works
The dryer shorted out. We replaced the piece all the wires attach to on the back but now nothing works but the inside light when you open the door.
  • 46 Answers
Check thermal fuse
Posted on Jun 26, 2009
Ge repair manuals
The fuse is a we4x800. It is mounted on the heater housing on the back wall of the dryer.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 30, 2013 | GE DCSR483EA Electric Dryer
No heat in my gas dryer, ignitor replaced, and sensor dry level does not light? I miss my dried clothes!
It sounds like your thermal fuse blew which is very cheap and easy to replace. Unplug your dryer and gain access to the back panel. Remove the panel and locate the thermal fuse. It is usually a white piece of plastic about 1/2" wide and 1 1/2" long with two wires attached to it. (Generally located near the bottom left as your looking at it) Unplug the two wires and unscrew the screw holding it in place. Replace it with the new one and reassemble everything. Good luck!
Apr 10, 2017 | Maytag Neptune MDG5500AW Gas Dryer
My dryer just doesn't turns on anymore, doesn't makes any noise, I set the timer and push the push-to-start switch and nothing happens, any ideas of what the problem may be??
hello on whirlpool dryers there is a start relay located in the rear of the machine to check this relay you would need a multimeter and to perform a continuity test to assure if the relay is still good this relay usually is one of the first things to short and mainly it shorts due to lint build up inside the machine the relay has two blue wires usually that are attached to it and if you connect the two blue wires and press the start button this would assure that the relay was bad as well do not leave these blue wires connected it would cause a short in your heater or other areas on your unit the piece sells for around 2-3 dollars if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks again Rick
p.s you have to remove the rear panel to access this relay
Apr 26, 2011 | Whirlpool Dryers
My dryer suddenly will not turn on!! I popped the top to discover that a wire had come detached from the "door switch," but after soldering it back, the dryer will still not turn on! There is...
Try soldering the two wires together and tape them to prevent shorting to the case. Try running the dryer--if it now works, replace the switch. If still nothing, try unplugging the machine for 5 minutes, and retry. Hope this helps!
Nov 22, 2010 | Dryers
Dryer not running.If you jiggle the timer it come on but stops shortly thereafter
It sounds like you have a loose wire on the timer. Unplug the machine and remove the vented piece of metal from the back top (where you would expect the back of the timer to be) make sure all connections are secure. if they are and problem continues, you will need to replace the timer.
Please rate this answer for me. Thank you
Mar 26, 2010 | Whirlpool GEQ8858H Dryer
Wiring for dryer timer GE model dvlr223ee2ww
If both are the same colour "brown" just replace and stick in empty space place on timer.
Vitally
May 14, 2009 | GE DVLR223 Dryers
Outlet wired wrong, nothing works
Ouch! That would of applied 220 to the controller. Do any lights come on or can you get it to do anything now that it's wired right?
Apr 13, 2009 | Whirlpool Dryers
Hello all! My name is Sarah and I have a problem with getting my Maytag dryer back together (model number: MDE3500AYM). I had to replace 1 of the drum rollers in the very back of the machine. I have...
When you say frame In my mind I see three sides attached, The door and front open, top with controls attached Like this maybe?
Smaller screws are innerframe longer outer in. You can do this! Just some minor set back...you got this far. Triangle Pieces I belive are corner protectors right and left lower, not positive tho. sorry. should be guide clips too, is the model bychance ending in W not M. Its hard to figure on what parts are left.... I will try to find you a diagram, other than the one attached
Jan 31, 2009 | Maytag HYE3658AY Electric Dryer
Dryer wont turn back on.
Hi!! Relax your thermal fuze has shorted out..replace your thermal fuze and all is fine..Good luck..the fuze is located by the motor blower inside the machine its white oval around 2 inches and has 2 wire leads to it good luckk.
Jan 04, 2009 | Kenmore 64992 Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
163 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
