Question about Kitchen Appliances - Others
Manual for 2012 hot water urn - Kitchen Appliances - Others
I installed oakbrook tub and shower faucet 48011 and no hot water is coming out either side just water. What could be wrong?
If you have just water coming out you have not urned on the hot water valve that was turned off during install. check other faucet for hot . If you have hot there its not the hot water tank its the hot side valve.
Sep 30, 2015 | Home
The pot perks but its just hot water when finished
You need a keepwarm element. Go to repairshack.com. Good luck. Ron
Sep 29, 2012 | Faberware 12-55 Cup Coffee Urn
I have a Faberware coffee urn that perks the coffee, but it isn't very hot. What is the problem?
The problem is the keep warm element. The reason, your pot perc's and it gets hot near the thermo, the thermo turns off the main element. The keep warm element is not on so after a small amount of time the water cools and the thermo turns the main element back on again, thus making the water hot. The K W element is supposed to be on all the time the pot is plugged in, it is instrumental in perking the first brew making it really hot, the thermo turns off the main element and the K W element keeps the water hot. The K M element is very a easy fix, it is the small looking white ceramic thing about 3-4" on the bottom of the pot.. When removing the screw from the main element you must hold the (leg) that the K M element is screwed to so it does not bend and brake off. Take your time and be firm with the pressure you apply to the screw, while holding it with a pliers. I have them. callahanronald@att.net Good luck
Feb 09, 2010 | Faberware 12-55 Cup Coffee Urn
I broke the pump tube for my Farberware Urn #155-A, 55 Cup. Does anyone have one?
New tubes are available from Goodman's, 10914 NW 33rd Suite 107, Miami, FL 33172. Tele: 305 278 8822. If you broke just the ceramic outer tube, it will still work alright. The purpose of that cermaic tube was to prevent the hot water being perked up the stem from heating the other water that hasn't been perked yet.....
Jan 17, 2010 | Faberware 12-55 Cup Coffee Urn
Making hot chocolate in regal 36 cup coffee maker
I've never done that myself but I have seen it done at a school function when my children were younger. If you make sure to rinse the valve thoroughly after you empty the urn, what problems could it cause?
Feb 12, 2009 | Regal Ware K6725 Kitchen Pro Bread Maker
Grindmaster P400 New Airpot/Urns not keeping coffee hot enough
this is a normal problem! first make sure you fill too top! also heat up urn with hot water prior to adding the hot coffee!
Dec 09, 2008 | Grindmaster Coffee Makers & Espresso...
Magic mill hot water urn, 7.0 Qt
I replaced the cover once. With the second cover, I found if I put a teflon glove on the back left, the pump worked properly.
Mar 26, 2008 | Magic Mill 8.5Qt. Electric Hot Water Pot -...
Water heats but stops perculating
Check the spring under the grounds basket on the pump tube. This is supposed to hold the end of the tube down in the heater well. It should compress when the lid is pushed down on the basket and twisted to lock in under the handles.  I have found a good source of parts for Faberware urns and percolators at goodmans.net. The thermostats and heating elements can be easily replaced and the urn returned to original condition. Rich of Colorado
Dec 26, 2007 | Faberware 12-55 Cup Coffee Urn
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
