Question about Vivitek D940VX Projector
My projector is getting dimmer. What do I do?
Gradient brightness
Make sure all your cords are plugged in. Try restarting the projector, make sure nothing is blocking the lenses. If the does not help, Call Radio Shack or Staples.
Nov 06, 2013 | Epson PowerLite 84 3LCD Projector...
The display projected is very faint. The lamp light is not blinking to indicate a problem. Is this an issue with the settings?
Check the bulb hours remaining through the menu. The bulb gets dimmer with age, so it could be close to life expectancy (2000 hrs regular, 3000 hrs Eco) and failing. The indicator light is based on hours only and will shut down the projector after (2100 or 3100 hours of bulb use), so it could still be the lamp failing or a power supply issue, especially if it's dim right from start up. Hope this helps.
Feb 08, 2011 | NEC VT695 LCD Projector
Out put is looking dimmer, picture seems to havefaded
Perhaps your lamp is on the way out? they do get dimmer as they age..
Jan 31, 2010 | HP Projector Lamp for vp6110, vp6120
Thought the bulb was bad, replaced and still no light.
where did you get the lamp from? if you got it from a reputable dealer, then i'd say the ballast is bad and needs replacing. if you got it from "bob's bulbs", then it may be the lamp. but the only way to test it is to put it in a known good projector.
Sep 11, 2009 | Sanyo PLC XU48 Multimedia Projector
My tv also has a green tint..
Is the T.V old, or second hand? Or does the picture look dimmer then you think it should be? If so then it could be that the lamp in the projector is coming to the end if its life. The lamps in projector tend to make the image on screen a greenish colour along with a dimmer look once it needs changing. It dosent just pack in though, it will stay like that for a while, but wont get any better. There could be a way of seeing how many hours the lamp has got left before being replaced on the T.Vs menu screen?
Jun 12, 2009 | Zenith E44W46LCD 44" Rear Projection...
Canon projector Dim & yellow
Yes, thsi can be a problem with the projector bulb and you may need to replace it already..
Hope that helps.........
Oct 03, 2008 | Canon LV-7230 Multimedia Projector
Bulb Exploded
did you have the fan on? usually it explodes because of excessive heat, make sure the fan works when you replace the bulb
Jan 16, 2008 | Dell 2200MP Multimedia Projector
MT 1055
As the lamp ages it will get dimmer this is a 1500 hour lamp look in the menu under information and it will give you the lamp time.
Jan 06, 2008 | NEC MT850, MT1050, MT1055, MT1056...
Vivitek D940VX Projector Logo
Top Vivitek Office Equipment & Supplies Experts
Electro Med Services...
Are you a Vivitek Office Equipment and Supply Expert? Answer questions, earn points and help others
