Question about Kenmore 22422 Top Load Washer
REPLACE BELT KENMORE WASHING MACHINE MOD.22632100
watugot
  • 290 Answers
SOURCE: belt on my kenmore 70 series washing machine
Your washer should be a direct drive unit, it has no belt. If you hear the motor running but nothing is happening you probably have a broken motor coupler. The coupler is about $10.
Pop off the trim pieces on each end of the console.
Remove the two screws that hold the console to the cabinet and flip the console back.
Remove the two clips that hold the cabinet to the rear panel of the washer and unplug the lid switch harness. The cabinet will tilt forward and slide off.
Remove the clips holding the water pump and move it to the side.
Unplug the wires from the motor and remove the clips holding it.
You will see the motor coupler.
Make sure you can turn the gearcase shaft with a pair of pliers so it is not locked up.
Post back and let me know what you find or if you need any help.
Posted on Dec 12, 2007
AlmostBob
  • 550 Answers
SOURCE: Changing a belt on a kenmore washing machine
99% of kemore washers (anything after 1950)
dont have a belt. and
the back does not come off for repair, the front does, with the removal of 2 screws
If the washer does not agitate or spin the usual cause is a plastic & rubber coupling between the motor and gearbox. replacement gearbox couplings now have a metal hub to prevent further breakage.
If this matches the problem you are trying to fix, reply & I will step by step the replacement process, its 2 screws, 2 bolts, a hammer & dowel & some time, to fix
Posted on Oct 13, 2008
jsrock516
  • 5911 Answers
SOURCE: need to replace belts
This model washer doesn't have any drive belts. It uses a motor coupling in place of a drive belt. If you need to replace the coupler, the following link explains how to do this:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
You have to remove the entire washing machine case to access the interior. The back does not come off. Its not as intimidating as it sounds, though. The part number is included in the link I provided and can be purchased at appliancepartspros.com for about $11. Just use the "Search By Part Number" feature. If you have any questions, please let me know. I hope this helps you.
Posted on May 08, 2009
  • 126 Answers
SOURCE: Kenmore mod. #417.44092500 high speed spin doesn't
replace speed control board located right rear base of unit
Posted on Sep 13, 2009
milten1
  • 1304 Answers
SOURCE: I need to replace the lid switch on my Kenore top
yes it is a very easy repair actually
you will ned to remove the two screws on the corners of the contol either in front or right on the back corner
flip the control over
you will see two copper dogs and a wire plug
remove those and now you can roll the cabinet out of place
the lid switch is connected to the bottom of the top of the cabinet
you can order the part from www.sears.com
make sure you have the model number correct
Posted on Oct 21, 2009
Washer will not spin. water drains. motor runs. Kenmore 80 series mod # 23822100 please help thanks
With old washers and with new washers sometimes you have to get in there and tighten the belt or replace the belt. Your problem sounds like this to me.Your question was posted sometime ago and you probably found your problem. If not please get back to me and I will be happy to help some more. GOOD LUCK.
Aug 02, 2011 | Kenmore 23822 Top Load Washer
I have a Kenmore Top load Washer won't drain
You must have a lid switch problem . I have a page I compiled which features lid switch replacement: HERE
Jan 11, 2010 | Washing Machines
How to replace belt? Kenmore Elete washing machine mod #110.24952300
Pop the spring loaded top and remove the front panel for access. Take pics with your cell phone to help in reassembly.
The tensioner connects to slits in the bottom panel near the motor pulley. Feed the belt through the tensioner and around the pulley.
FixYa.com advertisers sell replacement parts as do appliance parts stores in your area.
Dec 26, 2009 | Washing Machines
I need to replace the lid switch on my Kenore top loading heavy duty washing machine model# 22632100. I am sure this is the problem . Can I do this myself?
Oct 21, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore sewing machine mod 1703 motor runs but
By 'The wheel the belt is on' you mean the motor pully? If that is so obviously some oil has some how made way on the pully and the belt. Try to remove the belt and clean both wheels and the belt free of oil. This shd slove the problem.
If it doest then please send a photo of the arrangement showing pully and belt. U didnt mention if the machine is old or new. Did u oil it recently before trouble developed?
Oct 17, 2009 | Kenmore Sewing Machines
NEED DIAGRAM FOR PUTTING BELT ON WASHER MOD.#110 84090830
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.84090830
Look at the Drive Parts section.
Following is a detailed description of how to replace a belt on a Sears or Whirlpool Belt Drive washer.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=144&osCsid=b839fe494368f42b49a188855799bf00
This should walk you through it.
Oct 14, 2009 | Kenmore Washing Machines
Sep 12, 2009 | Kenmore Washing Machines
Kenmore washer won't drain
The symptoms you describe are often caused by a lid switch malfunction. It may be loose or not making good contact. If you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike in still intact. This is a small plastic piece mounted on the lid that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it. A replacement can be found at searspartsdirect.com. Just type in your model number and the part will be located under the "Top and Cabinet" heading. For instructions on how to replace a lid switch, click on the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
This is a simple and inexpensive repair if you wish to accomplish this on your own. A replacement switch usually cost between $25 and $35. I hope this helps you. Let me know if you require further assistance.
Aug 09, 2008 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
19 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
