Question about Toshiba E-Studio 206L Copy Machine
Fax receipt code shows a status code of 0050, What does that mean ?
  • 35 Answers
It means there is no dial tone on the fax line, is the rj11 plugged in properly [ (Line) on the copier, not he one labeled as (TEL) ], is the telephone patch defective, or you have an active phone on the wall jack, (test it it with an ordinary phone), or the receiving party is busy, try later, or try a different nunber.
Posted on Jul 23, 2014
FAX NOT SENDING
make sure your connected in the right plug one is for a hand set also see if your getting a dial tone could be bad line if that checks ok then replace lcu pcb
Jan 09, 2013 | Toshiba E Studio 2330C
How do I set automatic fax receipt?
If you got a satisfactory solution to the fax receipt issue, I would surely appreciate your sharing it with me. I don't think that any HP all-in-ones will give you a receipt from the recipient. I need this too.
Maybe I will reinstall Win Fax
Jun 02, 2010 | HP LaserJet 3390 All-in-One Multifunction...
We just got a new xe-a102, we do not need to print receipts...how do you turn off that function?
To disable receipt printing:
  • Press the Rcpt/PO key in the OP X/Z position. This key toggles the receipt printing status ON andOFF.
  • To check the receipt printing status, turn the mode switch to the OP X/Z position or press the CL key in the REG mode.
  • When the function is in the OFF mode, the receipt off indicator “_” illuminates.
To issue a receipt when receipt ON/OFF function is set to OFF:
If your customer wants a receipt after you finalized a transaction with the receipt ON/OFF function in the OFF
mode, press the RCPT/PO key. This will produce a receipt. If more than 50 items were entered, the receipt will be
issued in a summary receipt format. Your register can also print a copy receipt when the receipt ON/OFF
function is in the “ON” status.
Oct 27, 2009 | Sharp XE-A404 PC Desktop
I am trying to receive a 46 page document but I am only getting some of it. The first attempt resulted in me receiving 5 pages and the second attemp resulted in only 2 pages. I have checked the log for the...
If you are not getting any kind a jam indication on your end then it is most likely a phone line noise issue causing the transmission to fail. One thing you can try is turn off the ECM setting on your machine. This stands for error correction mode. If you have your manual you should find it there. ECM is the cause for most failures of the type you are describing.
Oct 21, 2009 | Canon Office Equipment & Supplies
I have a mfc620cn. I have replaced the cartridges
This error code means that the size of the paper your machine prints onto is different to the size that it has received from another fax....take your paper out and adjust the side guides put the paper back in and then see what it says...
There may be a button on your console that says 'memory' or
"memory status". pressing this key should erase any documents in the memory.
if none of this works turn it off and leave it off overnight, if in the morning when you turn it back on the memory should have been cleared....dont turn it off at the machine turn it off at the wall socket so the machine thinks there is a power failure...this should make the machine print out a status report when you turn it back on.
The above is for the fax problem. For the unrecognized catridge:-
This is a usual problem observed in times of loose connection or dirty catridge contacts. Please make sure that the catridges are clean ( especially the contacting end ). Try cleaning with alcohol.
Sep 14, 2009 | Brother MFC-620CN multifunction Color...
Incoming fax freezes system
Try installing the fax controller again, make sure to turn off fax machine, reboot computer and then after trying turning on your fax and send another document.
Nov 18, 2008 | Symantec WinFax Pro for PC
Receipt not printing
I believe this might help, not exactly familiar with this exact model but here it goes.
Receipt ON/OFF function
When you use the printer to issue receipts, you can disable receipt printing in the REG mode to save paper
using the receipt ON/OFF function. To disable receipt printing, press the Rkey in the OP X/Z position. This
key toggles the receipt printing status ON and OFF.
The register will print reports regardless of the receipt state, so the paper roll must be installed.
If your customer wants a receipt after you finalized a transaction with the receipt ON/OFF function being OFF
status, press the Rkey. This will produce a receipt. However, if more than 30 items were entered, the
receipt will be issued in a summary receipt.
Copy receipt
You can print a copy receipt by pressing the Rkey when the receipt ON/OFF function is in the “ON” status.
To realize this function, you must enable the function. Please refer to page 62 (Job code 63).
Nov 11, 2008 | Sharp XE-A404 PC Desktop
GETTING COM AS 634 INSTEAD OF OK STATUS WHAT IS THE REASON
This is what the code means:
Redial was not successful due to no response from the called station or wrong number dialed.
Note
: If busy tone was not detected, the machine will only redial once.
So the your fax machine is getting no response from the fax you're calling.
Hope that helps...
Jun 13, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Xerox F110 Fax Machine shows a status code 01 on the transmission report. what does it mean
the manual says it is the destination machine not answering.
Are you sure your phone line has a dial tone? Check that.
But 01 one means the machine is not connecting to the other after dialing the number. That does not mean you have a dial tone on the line.
May 02, 2008 | Office Equipment & Supplies
Toshiba E-Studio 206L Copy Machine Logo
332 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
