Question about Peg Perego John Deere Gator HPX Ride on Toy
I have 1 & 2 gears but no reverse
The gator runs good in 1 & 2 gears but nothing happens in reverse no wheel movement at all the reverse switch is depressed but doesn't go
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Check the switch and make sure that it is securely connected
Posted on Aug 14, 2017
  • 156 Answers
SOURCE: gator will only drive in reverse
I would replace the reverse switch as seen in here http://www.shopjandl.com/mepu0003.html and also the high low switch for this peg perego gator.
Sometimes the high/low switch will cause it to not go in reverse, so I would replace both switches in the shifter just to make sure.
They are really easy to replace. You can call these guys http://www.shopjandl.com/.
They know what they are talking about because they sell and repair them.
Posted on Apr 08, 2009
  • 19 Answers
SOURCE: !st gear won't work
I would replace the shifter assembly. It seems to be a better upgrade with the switches built into the shifter itself. It also has the wiring with it.
As long as the battery seems to work and the motors are going in one of the speeds, then there is not much to the vehicle.
It is a specific Peg Perego Switch assembly.
Hope this helps
Posted on Apr 21, 2009
  • 156 Answers
SOURCE: John Deere Gator 4x2 - Left Wheel doesn't move when in 2nd gear
I would replace the high/low switch and the reverse switch. One time a replaced the high/low switch and the reverse switch quit on me 2 weeks later.
You can also get the Peg Perego Gator Shifter that upgrades the vehicle.
You can get the parts and repair help at this site
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-switches-and-shifters.html
They have helped me several times.
Hope this helps
Posted on May 26, 2009
  • 156 Answers
SOURCE: won't run in low gear and won't go in reverse
It has a wire that has come off the motor or the switches in the shfter need to be replaced
I get all my replacement parts at
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html
because they also help me with my repair questions.
Hope this helps
Posted on Jul 10, 2009
  • 156 Answers
SOURCE: Gator stops suddenly and will not go with pedal depressed.
it could be a switch problem, or loose connection. I use the repair help at
http://www.mypegperegoparts.com/ when I need repair advise for these toys.
hope this helps
Posted on Jun 08, 2010
Only 1 wheel turns in 2nd nothing in 1st or reverse
you have a bad motor, whichever side isn't turning you need to replace that motor
Jun 28, 2013 | Peg Perego John Deere Gator HPX Ride on...
My grandson's Gator runs ok in 2nd gear, but doesn't do anything in 1st or reverse.
one of your motors must be bad or unhooked, you'll have to remove the dump bed to get at the motors, then verify that they are both connected, or it could possibly be the shifter switch
Apr 28, 2012 | Peg Perego John Deere Gator HPX Ride on...
Our gator will not go in reverse. Nothing happens at all when we put in in gear to back up.
probably a bad/disconnected shifter switch first of all check to make sure that the shifter switch is connected underneath, you can order a new one here www.powerwheelsoutlet.com
Aug 31, 2010 | Peg Perego John Deere Gator HPX Ride on...
Hope this helps
May 21, 2009 | Peg Perego John Deere Gator HPX Ride on...
Gator will only drive in reverse
Mar 28, 2009 | Peg Perego John Deere Gator HPX Ride on...
Peg Perego Gator Ride On Toy
Sounds like the gears are stripped. If a bunch of teeth are missing, only the high speed gear will spin the gears fast enough to move the gator forward. I just bought a used one and found it pretty easy to tear apart and diagnose as similar issue. The gear boxes, located inboard of each wheel contain plastic gears and strip relatively easy if the shifter is moved , during motion from forward to reverse.
Aug 11, 2008 | Toys
PEG PEREGO JOHN DEERE GATOR
Problem #1:If you have taken the high speed safety device off the stick shift(small red plastic block screwed on below the yellow stick shift housing) then your high/low speed switch has gone out. There are two motors(one on each back wheel) that both have to come on when in high speed. Only one comes on for low speed. It is the switch under shifter that is not spring loaded. hi/lo switch #MEPU0002 available at www.tigerimports.net for $11.00 plus $2.00shipping That is where I got mine.
Problem #2: Sounds like you need hi/lo switch and possibly forward/reverse switch too. Before buying forward/reverse switch try putting a little grease on the white plastic assembly that engages the forward/reverse switch between the top piece and the piece that pushes down on top of the switch. Sometimes they just stick enough to stop switch from depressing. It is the switch under shifter that is spring loaded.Forward/reverse switch #MEPU0003 $11.00 plus $2.00 shipping @tigerimports.net
Jul 19, 2008 | Toys
Peg Perego John Deere Gator HPX Ride on Toy Logo
57 people viewed this question
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
