Bauknecht wak/d 7416 shows the errorcode f08. What to do?
Bauknecht wak 7508
There is a filter on the drain pump. You should clean it out and see if that is the problem. You can take the bottom panel off the front if this is a front loading machine. If not you need to lay the washer down so that you can see the bottom. Be ready for lots of water! The drain plug is large and it unscrews.
Apr 11, 2014 | Washing Machines
BAUKNECHT WA 709 SC
my BAUKNECHT WA 709 709 SC washing machine doesn't work what should I do? no one could fix it
Aug 27, 2012 | Washing Machines
Bauknecht washing machine WAK 1400 ex. Loud rattle in drain pump, but clean filter and no blockage. Impeller looks OK, spins fine dry. No odd sounds from motor without impeller. Is there a guide for the...
Have the drain pump connected off line and tested, if there is the nosie then open and clean well try to back flush by using a water from the reverse direction.
If the noise has susbsided then reconnect to cirruit and test with load.
If there is play in the impeller it can makea noise , you remove and grease the shaft to set it in, if noise is absent then might need to put in worn bearings.
Sep 19, 2010 | Washing Machines
Wd640 showing f08
Code F08 indicates heater relay stuck.
  1. Check pressure switch connections.
  2. Check heater connections.
  3. Check control connections.
  4. Check and clean pump filter.
Please rate my sol;ution.
Thanks.
Nov 15, 2009 | Hotpoint Aquarius WD640 Front Load...
My hotpoint is showing error f08
F08 error code: for hot point washing machine indicates Heater control or NTC (Thermistor) temperature sensor problem.
Sir, I hope this helps.
Sep 17, 2009 | Washing Machines
Fuser Gear Md No. LJ 7416
You will need to purchase these gears from a brother dealer but I warn against just changing the gears you mention, fuser driver gear in printer frame will be ok unless chipped, but usally the big gear on the fuser goes as does a little white one next to it, and these are breaking becase the fuser is hard to turn, if you just change the gear, the fault will reappear after a little use, best bet is to replace fuser assy (approx $150)
Oct 27, 2007 | Brother MFC-8840D All-In-One Laser Printer
What does F7 Means?
The F7 means that the drain filter is blocked or your water pressure is low. Check and clean filters. Good luck !
Apr 25, 2007 | Bauknecht 24 in. GSF8984 Free-standing...
Washing Machines Logo
147 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
