Question about Toshiba e-Studio163 Copier
My printer is TOSHIBA e-studio 403s. I cant print. Error Tray Media Mismatch: 461. What can i do
4 Suggested Answers
SOURCE: Print driver for Toshiba E-Studio 3511 Copier/Printer for Window
You can go to http://copiers.toshiba.com and download it.
Posted on Feb 04, 2009
SOURCE: Toshiba e studio 163 printer
driver e-studio e 163 , 203 for winxp
Posted on Mar 25, 2009
  • 92 Answers
SOURCE: Wrench - Toshiba Studio E-28 error code C82.
could be a sensor blocked and the machine thinks there is paper present follow the small holes on the tray to locate sesor also keep in mind u can unplug the sorter and ur copier will work
Posted on Jun 28, 2009
My Toshiba e studio 352, when i copyed 200-300 pages then suddenly error occour e 010 then the machine does not copy a single page, cooling/stop machine 10 or 20 minute then i start copying again
sounds like it got a bit hot
tray holds 500 pages doesnt mean it can copy 500 in one session of copying time
Toshiba Studio 352 Copier Studio352
cant see it but
I was looking at the specs to see how many copies per hour it is rated
Jul 03, 2016 | Toshiba Office Equipment & Supplies
What would be causing our Toshiba e-studio 350 copy machine to mis-align margins when printing a document?
This involves 2 different sizes coming from 2 different cassette. 11x17 tray needs adjustment .
Sep 11, 2014 | Toshiba e-Studio 350 Copier
Paper size mismatch is appearing on the screen
if that is when your printing you have to check and be sure the paper tray size is set correctly. You press the machine status button and make sure, tray 1, 2 and the bypass are set to the proper size paper.
Nov 03, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Konica Minolta paper mismatch problem
make sure that you specify the same paper size in the print dialogue window - i.e., in MSWord go file - print - properties - and make sure paper size in the dialogue box matches media type in printer tray
Mar 20, 2009 | Konica Minolta magicolor 5430 DL Laser...
Mar 20, 2009 | Toshiba e-STUDIO 282 Black and White...
TRAY SELECTION
I cant using bypass tray for printing. I set A4 for paper size to every places. But it tells the papersize is mismatch?
Jan 14, 2009 | Toshiba e-Studio163 Copier
HP 6180 Printing Problems
Are you getting the paper mismatch error message?
If yes, see below...
I will ignore the normal solutions to a "paper mismatch" error such as your settings not matching your printing media. Obviously, check these first:
http://h10025.www1.hp.com
If your problem is not solved with the above steps, you have an issue with your "spot sensor" and it needs to be calibrated. Instructions:
1. Press * and # at the same time, and then release both keys.
The display reads "Enter Special Key Combo".
2. Press 3, 2, and then 9, releasing each key before pressing the next.
The display window should read "Service: R0622M" with a revision number.
3. Press the right arrow button once.
The display should read "System Configuration".
4. Press Enter or OK.
5. You will be prompted to enter serial number. Do not enter any information
on the unit.
Press the right arrow button until "media sense calibration" appears in the
display.
6. Load Paper into the unit and then press Enter or OK.
7. Media Sense Calibration process will take place.
Dec 31, 2008 | HP Photosmart C6180 All-In-One InkJet...
34 incorrect media
34 Incorrect Media message appears if the printer has detected a mismatch between the type of media requested by the user and the type of media actually loaded in the paper tray.
To attempt a resolution for this issue, please do the following:
  1. Press the green GO button on the printer operator panel. Printing will resume, but the printer must go through a POR (Power On Reset) in order to clear the message.
    NOTE: The printer does not automatically reprint the page that generated the error message.
  2. Verify that the media you are using is supported by your printer in terms of size, weight, and input source.
  3. Using the printer operator panel, verify that the type of media loaded in the paper tray matches the Paper Type setting in the Paper Menu. Detailed instructions for navigating through the printer menus and changing the media type setting are provided in the C510 User's Guide.
    • If the media type setting is incorrect and cannot be changed, there may be an issue with the media type sensor. Proceed to step 5.
  4. Using the printer's operator panel, verify that the paper loaded in the paper tray is the size listed under Paper Size in the Paper Menu. Detailed instructions for navigating through the printer menus and changing the paper size setting are provided in the C510 User's Guide.
    • If the paper size changes to an incorrect setting or cannot be changed, it is likely that the paper size guides in either the 250-sheet or the 530-sheet paper tray are not set correctly. Remove the media from the tray and verify the location of the media guides.
  5. Power the printer off and then back on again.
  6. Resend the print job to the printer.
  7. If the error persists, you will need to contact Lexmark Technical Support for assistance. Please obtain the printer serial number before contacting Lexmark. If possible, call from near the printer as this will allow for the most accurate possible diagnosis.
Hope this will help you please let me know if it worked and don't forget to vote..
Cheers
Dec 18, 2007 | Lexmark C510 Laser Printer
Toshiba e-Studio163 Copier Logo
144 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
