Question about Sharper Image Super Wave Oven Accessories
Where do I purchase a halogen replacement bulb for the Sharper Image new wave oven?
I've got a built in double oven, SCD302TS with no light in the lower oven. Replaced bulbs with known good but no dice. Top oven lights when lower oven is opened, so it's not the switch. Any ideas?
i just looked up your model number and when you change a halogen bulb you should buy the bulb and socket or lamp assy. part 14-38-437 and that's the part the bulb plugs into you can't get it anymore,i just was on sears and repair clinic and it's unavailable
Nov 06, 2017 | Ovens
Will not turn on
Could you please provide more specifics? What brand as well as the model #? Does the display activate or is it completely blank?
Nov 26, 2015 | Sharper Image Super Wave Oven Accessories
Where can I download a Owners Manual
http://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=7&ved=0CEMQFjAG&url=http%3A%2F%2Fecx.images-amazon.com%2Fimages%2FI%2FA1T226kZkES.pdf&ei=UVzKVJW_HeTY7AaB9YGwCQ&usg=AFQjCNGunI_0JtjH_k9H-uEkhB5T6hIpsA&sig2=wmpvkWusFFJY-dl0Us7ebA&bvm=bv.84607526,d.ZGU&cad=rja
Aug 16, 2014 | Sharper Image Super Wave Oven Red
I plugged in in for the first time after unpacking it and my super wave oven will not heat
Ship it back and get a replacement, don't forget to get an RMA number from sharper image.
Oct 27, 2013 | Sharper Image Super Wave Oven Accessories
Replace light in KEMC378KSS microwave
The oven lights are 12-volt, 5-watt maximum halogen bulbs. They
will come on when the oven door is opened. On double oven
models, both upper and lower lights will come on when either
door is opened. The oven lights will not work during the Self-
Cleaning cycle. When the oven door is closed, press OVEN
LIGHT to turn them on or off.
To Replace:
Before replacing, make sure the oven is off and cool.
1. Disconnect power.
2. Remove glass light cover by grasping the front edge and
pulling away from oven
3. Remove bulb from socket.
4. Replace bulb, replace bulb cover by snapping back into wall.
5. Reconnect power.
Feb 04, 2013 | KitchenAid KEMC378KSS Electric Double Oven
Where can I get a replacement heat element for the sharper image item no. 8246si?
sears online sells them you can order it or if you have one near you go in and get one.
Apr 14, 2012 | Ovens
My GE oven isn't lighting but the electrics work...What should I do? Please help
Bulb required: Manufactured by Aglaia for GE, 130V 35W Halogen bulb
There is a grille above the door and clock/cooking controls that extends the width of the unit. You need to remove this to get to the light receptacle. With the power to the unit off (unplug if you have access to it), get on a chair with a Phillips head screwdriver. Look down from the top and you will see two screws about 6" in from the ends. If you don't see the screws, open the cabinet doors above the unit (mine were blocking the screw heads). Remove the screws and set aside. Pull girlle towards you at the top being careful not to break the tabs at the position where the screws you just removed are located. After the tabs are out the grille should lift up (there are three hook-tabs along the bottom). Set it aside. Over toward the right you will see a smaller vertical grille. Just to the left of this there is a void with a Phillips head screw facing you. Remove the screw from the receptacle tab. Lift up the receptacle tab on the right. When the receptacle is clear on the right, move the receptacle to the right to release it from the tabs on the left. Lift the receptacle up until it clears the housing it just came from. Pull it gently toward you, rotate it bottom-toward you, and you will see the bulb to be replaced. My bulb was lightly held in using white silicone and removed easily by pulling it in the direction it was pointing. A word of caution about Halogen bulbs: When handling new bulbs be careful not to get any grease on them and handle them with clean cotton gloves or a clean t-shirt. Grease and oils from even clean hands will cause the bulb to burn out quickly. Replace the receptacle being careful to make sure the electrical wires are not pinched by the receptacle housing. Replace the screw; replace the grille; return power to the unit. You're done!
Lamp Halogen ranging in price from $8.10 to $10.71.
Jan 05, 2011 | GE Profile JTP18 Electric Single Oven
We have recently purchased a Coopers halogen oven. I cooked a frozen fruit pie in it and the pastry looked beautiful, but when it was cut open the middle was cold and the pastry under the fruit not cooked....
Frozen food should be defrosted before cooking in halogen ovens.
Halogen ovens use only radiant heat and will not cook the centre of frozen food.
Jan 21, 2010 | Ovens
Need to replace light bulb in kitchen aid microwave
KitchenAid wants $58 for the replacement bulb. I bought it for $1.99 from www.lightbulbsdirect.com and it works just fine. The Item number is Q5G412V. It is a halogen 5-watt, 12-volt bipen G-4. Replacing the bulb requires some dismantling of the microwave. At first I was nervous about removing so many parts to get to the bulb but in the end it really wasn't so bad. The only tool I needed was a Phillips screwdriver. I surfed the net a eventually found instructions left by a friendly Blogger that guided me through the whole process. KitchenAid engineers were so STUPID when they designed this microwave. It takes two hours to replace a bulb that should take 5 minutes. Oddly enough, replacing the bulb in the normal oven below the microwave oven is a piece of cake.
Jan 19, 2009 | KitchenAid KEMC308 Electric Double Oven
Sharper Image Super Wave Oven Accessories Logo
235 people viewed this question
Top Sharp Ovens Experts
JOHN LAPIER
Are you a Sharp Oven Expert? Answer questions, earn points and help others
