Question about Tecumseh Heavy Machinery
What replacement spark plug for 8.0 hp tecumseh wood chipper
wadembly
  • 448 Answers
SOURCE: Chipper won't start
what engine do you have im guessing a briggs & stratton was it running previously or sitting awhile it can be a few things the flywheel key could be sheered or the points are bad or the flywheel & coil are rusted check flywheel & coil to see if rusted if so take coil off mild sand paper like 80 grit i beleave clean both to get the right gap between flywheel & coil turn the flywheel alittle bit so the magnets won't touch coil or if coil still of set flywheel to where it will touch magnets fat peice of sand paper not folded but flat sand paper about .020 gap between magnet & coil if you place sand paper against the flywheel magnet then set coil against sand paper & magnet that should give you 0.020 gap & it should start if not e-mail me i will guide you through everything to get it started
Posted on Jun 05, 2009
  • 3 Answers
SOURCE: i have a brush master chipper was working but has
look at the magnita the round **** under the coil you make just have to sand it with a fine sand paper and maybe the under side of the coil
Posted on Jun 18, 2009
SOURCE: looking for manual for troy-Bilt super tomahawk wood chipper
here is the link to the manuals for the 47266 http://www.brentchalmers.com/
enjoy :)
Posted on Sep 13, 2009
mowerman1857
  • 389 Answers
SOURCE: How to remove impeller assembly from chipper
You can download a PDF2.gif manual for your chipper at ( www3.sears.com ) Type your model number like this ( 247.795890 ) It will show you a parts list for it and also there will be a place that says "Manuals" click on that and it will download to your computer2.gif where you can either save it or print it out or both
Posted on Sep 16, 2009
  • 62 Answers
SOURCE: 8 hp Tecumseh HM80 won't start
plugged carb
Posted on Sep 26, 2009
Is it hard to change a magneto on a 5.5 hp Tecumseh engine?
How old is the gas in the tank? If it is older than 2 months drain it out and put in fresh gas and try again. Have you seen spark jump across the spark plug gap? To check for spark I use a spark checker. One end goes to the plug and the other to the spark plug lead. If you have spark you see a light flash which is more easy to see.
Sep 16, 2014 | Tecumseh Engine 5.5hp Horizontal OHV MTD...
I have a Tecumseh OHH55 on a wood chipper. I replaced plug, oil, new fuel and cleaned up. I cannot get it to start. Carb was also cleaned. Any suggestions before I take to a repair shop.
Is fuel getting to the carb? Check the fuel line it may be plugged. The rubber deteriorates after many years and plugs up the line and or jets. Its always best to replace the fuel hose when you rebuild the carb. Have you checked for a spark at the plug?
Aug 09, 2014 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
What is sparkplug gap on 8 horse tecumseh snow blower
Clif - I have two items in my garage with Tecumseh engines on them in that HP range and they both specify .030 spark plug gap in the instruction manual.
Dec 03, 2013 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Need spark plug type and gap setting Craftsman 247.775870
Champion N4C, Gap: .030
Air filter: tecumseh 36046
Pre-filter: Tecumseh 36634
Jun 20, 2013 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Need new air filter for a tecumseh shredder chipper 10 hp
You can look up the air filter with the model number and order it over the internet from a website such as partstree.com, but there are others. Or, you can get the model number and go to your local small engine repair and parts shop. Mine had it on the shelf. If your chipper/shredder is like my 8 HP Craftsman with a Tecumseh engine, then as you are looking at the engine, look on the left side of the shroud or cover and way down low on the curved portion is a label with the model number on it.
I hope this is helpful for you.
Aug 22, 2011 | Tecumseh Heavy Machinery
Tecumseh engine has no spark. spark plug has been replaced
iF IT IS EQUIPPED WITH A CDI (CAPACITOR DISCHARGE IGNITION) IT IS PROBABLY BURNT OUT AND MUST BE REPLACED. IF IT HAS A COIL, TRY CLEANING THE MAGNITO AND COIL WITH EMERY CLOTH THEN REGAP IT.
Feb 09, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Need replacement spark plug for 4.5 hp Tecumseh; model number YTPXS
In my shop, I use Autolite brand plugs. Your engine would have come originally with a #255 or equivilent. Most shops will upgrade that plug to a #458. It is slightly hotter and gives a more efficient burn. You can also use a Champion J19LM or an NGK B4LM.
Oct 08, 2010 | Tecumseh Heavy Machinery
MTD 5hp. Starting and running only while I spray
Remove the fuel line from the carb. Drain fuel tank and blow thru fuel line until clear. If you use compressed air be very careful to use LOW pressure. I just use my mouth. reinstall fuel line replace the fuel filter, add a new spark plug for good measure and refill gas tank
You should be chipping away right soon!
Mar 04, 2010 | Garden
I have a Tecumseh 4.5 2 cycle engine on my snow
fuel filter thats were i would check fuel will turn gummy in the filter if it sets
Feb 10, 2010 | Yard Machines 24a 021h700 4.5 Horsepower...
Heavy Machinery Logo
37 people viewed this question
Top Tecumseh Heavy Machinery Experts
methjd
Bilral
Level 1 Expert
szanghi
Are you a Tecumseh Heavy Machinery Expert? Answer questions, earn points and help others
