Question about Pool & Spa
Lay z spa heater trips power - Pool & Spa
2 Suggested Answers
  • 3 Answers
SOURCE: where can i buy a replacement heating element for ...
I got a new heating element off eBay, it was just a double straight line one like the one already in the metal tube (in the pump). It fit, i wired it up and it works!!
Posted on Jun 12, 2010
My lay z spa just set up for spring. Pump is working fine, heater trips breaker when activated
call an electrician as there is a dead short in the heater element
Apr 17, 2017 | Pool & Spa
Why is my lay z spa not heating?
if the heat light comes on but doesnt heat bad heater element if red heat light doesnt come on need new temp sensor
Aug 31, 2014 | Pool & Spa
Lay z spa heater
with power disconnected take off cover take off heater leads (remember where they go take a picture ore write a note if you turn it on and doesnt blow fuse its a bad heater element
Jul 10, 2014 | Pool & Spa
Lay z spa heater pump
need more info does whole thing trip off sounds like shorted heater element if you are able to disconnect heater leads and thing stays on bad heater be careful its either 110 volts or 220 volts if your not familiar with this call a professional
Jan 25, 2014 | Pool & Spa
I have a Lifestyles Phoenix Spa with a Wolfpac model 12404GH controller. The onboard circuit breaker trips when the temperature control potentiometer-knob is turned up past water temperature and when the...
IF when the spa control calls for heat and it trips the breaker when the heater comes on then you have a bad heating element and it will need to be changed.
Disconnect the power to the spa. Disconnect the two wires going to the heater and then turn the spa back on.
If the spa stays running without the heater attached then that will be your source of trouble. New heater and you will be all fixed up.
Jan 28, 2011 | Home
Colman Spa trips GFI what is most common problem? GFI test good. Pump disconnected still trips, is heater most likely? Can you replace only heater? thanks
this should be simple ...
1.shut off the power
2.disconnect wires to heating element
3. turn power back on and see if it works if so replace heating element 45-95 dollars
if it still trips unplug all the cables from the pumps blower ozonators and see if it runs now,,,, if so plug each cable back (one at a time) until it trips again.if it trips that the problem pump etc.
99 percent of the the time its not the gfi its a device that is wet or shorted out ..Try everything else before replacing the gfi
Dec 31, 2010 | Balboa Instruments BALBOA 30kW HEATER ASSY...
Spa keeps tripping breaker shows pr
two main reasons breaker trips is the pump motor jammed [not turning]or the heater shorted out --disconnect power open access panel disconnect the lines to the heater turn on power if breaker trips than motor /pump problem if doesnt trip than heater problem can order heater replacement online or pool spa store--if motor pump check pump for debris and motor for lube if u can turn shaft or impeller oil motor and work it into bearings if still not turning possible need to replace motor unit
Apr 26, 2010 | Heritage Pool & Spa
Lay z spa water pump is faulty where can I get a
Hi Im Chris From BVL Elecric,
I cover Bournemouth and surrounding areas and supply solutions to most home electrical problems.
A lovely lady customer called me out today to diagnose faulty
LAY-Z-SPA
pump/heater that kept tripping the RCD.
After scouring the net and finding this same problem over and over again but no solution,I decided to get personal with the blighter!!!
RESULT:- problem solved,
Customer very happy,
no new parts fitted,
water heating fine now.
If you live in my coverage area,have a LAY-Z-SPA that is faulty,no or limited warranty then give me a ring and I will be only to happy to come on over and fix it for a small fee.
just think that dead spa/pool heater/pump could be heating your water again tomorrow and there is plenty of summer left to enjoy it.
You can find my details quite easily , just google BVL Electric Bournemouth
Dec 27, 2009 | Pool & Spa
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
