Question about Bolens 13.5 HP Manual 38-in Riding Lawn Mower with Briggs & Stratton E
Blade will not engage - Bolens 13.5 HP Manual 38-in Riding Lawn Mower with Briggs & Stratton E
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 181 Answers
There must be:
  • Someone in the seat
  • Not in park/idle.
  • A working blade start switch
  • A non defective PTO clutch.
  • Undamaged blade and greased blade bearings.
Posted on Jan 03, 2015
Have a craftsman EZ3 917.272121 mower engine e stalls when blade switch is pulled
If you are sitting on the tractor seat and the engine stalls when engaging the PTO mover blades I would check the switch under the seat.
This seat has a saftey switch to assure that the operator is in a safe location before engaging the the blades. Also if the blades are engaged and the operator leaves the seat the blades will stop. If a young rider with insufficient weight the blades will not engage.
26147998-f1dbbl4o5m3nghfc10hihvyr-4-0.jpg Hope this helps?
Mar 31, 2016 | Craftsman Garden
What will cause blades on J.Deere G100 mower to Freely turn by hand without causing Spindles or belt to turn even though Bolts are still tight and when installed Blade turned only if spindle turned
Do Ray:
If the blade engagement lever is in the disengaged position, the belt will be loose, allowing you to turn the blades by hand. If you place the blade engagement lever in the engaged position (with the motor off) it will be hard to turn the blades because of the tension on the belt. If the blades are still easy to turn with the blade engagement lever in the engaged position, you need to replace the blade drive belt!
Jun 15, 2015 | Garden
Why don't the blades engage?
Blades Engage via a pully system. Once you move the lever to engage the blades, the belt tightens and the blades engage. It is possible that your belt is broken or has gone out of track with the pulleys. If you know the belt is ok, then it is probably a bearing in one of the blade mounts.
Aug 12, 2014 | Garden
Safety switch located
Micro switches will just stop the engine if the blades are engaged and the operator leaves the seat, or will stop the engine cranking if the blades are engaged, it will not stop the blades from engaging.
Sep 06, 2012 | Murray Garden
I have a 36" simplicity
There are two safety switches that work off each other when the blades are engaged. The seat switch and blade engage switch. Someone has to be in the seat when the tractor is not in neutral and or when the tractors blade engage lever is engaged. Other reasons for the tractor dying would be that the blades are hitting the deck. That could be caused by bent pulley shaft or bent blades or even a bent deck. First check the blades and make sure they spin freely by turning the tractor off and the blades are not engaged and spinning the blades (with gloves on so you do not cut your self)
Test the blades by measuring on side of the blade to the inside of the deck then rotating the blade 180 degrees and meandering it again (same side of blade 1st time measuring the blade is pointing towards the outside of the deck 2nd time of measuring the blade it is pointing to the inside of the deck). Do the same to the pulleys.If the blades are bent you may want to check the pulleys as well. sometimes both may be bent and the cost of replacing bothe is not worth it. You may want to check with a service repair person. If I can help further please contact me
Jul 06, 2011 | Garden
Blades won't engage
do you here it making any noise when you try to engage the blades
Oct 19, 2009 | Garden
Craftsman riding mower noise when blades engaged
With blades on and engine off reach under and wiggle each blade up and down. If you have excess play you will need bearings.
Aug 12, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
What ingages blades ,blades not engage
On most riding mowers flipping the handle to engage the blade causes an idler pulley to engage the drive belt, which takes up the slack in the belt and pulls it against the drive pulleys. A few odd-balls have an electric clutch to engage the blades.
Jul 10, 2009 | Garden
My blades wont engage and just hear click sound?
No permanent solution, but you probably can get by once by "riding" the clutch engagement lever - pushing it only part way forward and holding onto it.
Jun 27, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Blades will not engage
Lever that adjusts height does not make blades turn. You need to engage the blade lever and if you can not tell if the blades are turning then they probably aren't. check belt it could need replacement.
Apr 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Bolens 13.5 HP Manual 38-in Riding Lawn Mower with Briggs & Stratton E Logo
167 people viewed this question
Top Bolens Garden Experts
cwradio73
ray gallant
Van Phelps
Are you a Bolens Garden Expert? Answer questions, earn points and help others
