Question about Peak Performance Rechargeable Led Lamp Pkcotr 30 Led Light Cordless Flashlight
How do i change bulbs
Peakperforman pkco1mb bulb needs rep how
When I turn my left turn signal it flashes really fast until I press down on brake pad than it slows down and works cirrectly
This usually means that the front, or rear turn signal bulbs is bad...also some turn signal tail light bulbs are multi-purpose...same bulb lights for turn signal and brake light...You should be able to remedy this for the cost of a bulb...your owners manual and the parts counter rep can confirm the correct replacement bulb...Hope this helps.
Apr 05, 2014 | Cars & Trucks
No tail lights only brak and blinker
Should be under warranty...also Dealer should definitely provide courtesy loaner...contact the regional rep as necessary...could be serious future electrical problems...In rare cases, the wrong bulbs could be installed...one way tips...instead of dual (twin bulb tips) I have seen this before...replace both bulbs with the correct ones...Hope this helps.
Mar 21, 2014 | 2007 Chevrolet Malibu Maxx LTZ Hatchback
I just bought a 35 w halogen bulb from lowes for my GE truetemp profile JKP56 built in oven. I just spoke to a GE rep who sells the bulbs and he said the bulb has no replacement numbers so I don't...
If the bulb you bought from Lowes is a 35 watt bulb and it screws in, then it will work just fine.
Appliance parts people love to sell you the "one" specific for your model because most of the time it is more profitable for them.
Good Luck!
Joey
Jun 11, 2011 | GE Profile JKP56 Electric Double Oven
Interior light went out. How do I replace it? I read someone had a similar problem but the expert said to call a service rep.saying that it's beyond the expertise (safety) of owner. So, do I call a...
It is easy to replace if you are handy. There is normally a small piece of glass with clips either side or a glass cover that unscrews which can be a little hard to turn sometimes. If it is the glass cover that unscrews dont be scared to use multigrips as the glass is quite tough but try to be gentle.
Feb 08, 2011 | Ovens
Toyota Matrix 2006 Low beams do not turn on, High beams OK I found fuse box under hood, but no manual to decide which fuse is which
Ther will be no separate fuse for high and low beam. Just one fuse for headlights. Change the bulbs. Buy the dielectric jelly, store rep will know what it is
Feb 03, 2010 | 2006 Toyota Matrix
WD-65731new bulb and still no tv
sounds like 2 me u r buying bulbs off the internet bad idea iner net comp have a rep 4 sell rebuilt lamp reman sold as new u r a victum probbaly a bulb shoud last 2000 hrs about 2yrs buy from sylvania u may need alight engine now . exp new 800$ repaird 500 pts the way 2 fix ur problem without spendig lot $ call pts.com electronics will rebuild 4 300$ a1 company good luck
Aug 08, 2009 | Mitsubishi WD-65731 65" HDTV
Replacing dashboard lights on an 2000 Oldsmobile Silhouette Van?
the light bulbs are not replacable unless you can solder, you have to replace the complete instrument cluster, get one from a junk yard 100 bucks.
Jul 24, 2008 | 2000 Oldsmobile Silhouette
Palm beach 48"
Me too. I went back to Home Depot. They gave to me the phone number for Hampton Bay - 1-877-527-0313. I will call them tomorrow after they open to see what the deal is. it looks to me like the JDE11 is a mini-candelabra base. The lady in the fans at Home Depot said that all of the light kits were changing to the smaller based halogen lights. BUT, you'd think that they'd carry the light bulbs that have to go in the light kits they sell!!!
May 12, 2008 | Hampton Bay 48 In. Palm Beach in Textured...
Blowing Bulbs in the 50WE655
must replace with original bulb by sony,others don't last,ask for a refund from the lti company or a replacement if they say different at no cost to you.
Sep 10, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
Peak Performance Rechargeable Led Lamp Pkcotr 30 Led Light Cordless Flashlight Logo
Top Peak Performance Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Peak Performance Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
