Cash register with PS-700e bar code reader.I purchased one PS-700P
the clue is in what youve typed
you used to use a 700E type
you replaced with a 700P type
perhaps look for the 700E type that matches the older type you have
i would assume the last letter is the series ident so the one you replace it will it newer
perhaps doesnt communicate in the same exact way
necesito el diagrama de conexion interno para lcd kds 700p. i need de pinout tech info for lcd monitor kds model 700p myy wire is broken........ i just adapt a new part used,,,?
Can you hear it ring when u try to call ur number using a different phone? If yes, maybe it isn't aligned properly or check the connector. If no, the software is crashed, it needs a software reflash/reprogram
my monitor samston 17`` have a problem with screen ten minute after on it`s become on / off screen ( it`s black, it`s white ) when it`s happen the wording can read, when it`s on.
make sure first of all that there arent any screws missing or loose in the back by removing the battery cover....thats can cause the keypad buttons to not have a good connection to circuit board... if thats ok then you can use a toothbrush and some alcohol (denatured alcohol if possible) to rub and clean the keypad. If all that fails, I know that Sprint offers repair for their phones.
