Question about Garden
What is john deere 6200 head bolts torque - Garden
  • 10865 Answers
SOURCE: need head bolt torque for Brigges Stratton 18 Hp
210 to 230 inch pounds. Torque in a crisscross pattern upper left lower right upper right or left or right.
Posted on Jul 10, 2009
wireguy212
  • 1627 Answers
SOURCE: Hello, does anybody know the torque setting for
I found the tech manual one lin but it can"t be opened since deere is updating it.I will see if we have the book"tm1974" at the dealership in the morning and get back to you.
Posted on Oct 28, 2009
nova2nv
  • 197 Answers
SOURCE: I have a John Deere LT 1`33 lawn tractor with a 13
I believe they are 8mmX35mm.
Posted on Nov 14, 2009
nova2nv
  • 197 Answers
SOURCE: torque spec on a 425 john deere head
Initial torque-115 inch pounds,final torque-186 inch pounds.Intake manifold is 53 inch pounds on all 8 screws.Valves set at 0.010 on all 4.If you go with the new style valve cover gasket {the flat one} be sure to leave the old o-ring in valve cover to keep the new gasket from splitting.
Posted on Feb 09, 2010
wireguy212
  • 1627 Answers
SOURCE: how do you remove the blade clutch on a john deere
It would be helpful if you could tell me what model you are working on,but i can tell you that you will need an impact gun no matter what model you have.Let me know how you make out.
Posted on Aug 13, 2010
What is the torque for the axle pivot bolt on a John Deere L 130 lawn tractor
the bolt is M12x80?
if so you have 2 options
if the bolt is strength 8.8: 93Nm
if the bolt is strentgh 10.9: 137Nm (most unlikely)
strength is shown on the top of the head of the bolt
Aug 13, 2017 | John Deere Garden
What do i torque the head bolts at?
John deere is proprietary. That information is not public.
Sep 02, 2015 | John Deere 4020 Gas & Diesel Tractor...
What torque do I use when replacing the cylinder head on a John Deere 110, Briggs and Stratten 19.5 hp
Stuart,
Do an internet search for torque specs 2011 John Deere D110. You should be able to find the service manual for this product easily.
Sep 29, 2014 | John Deere D110 42 in. 19.5 HP...
Fitted new head gasket
They are head bolts most of the time. 110 ft. lbs
Dec 25, 2013 | Garden
What is the proper sequence for the head bolts on a deisel 3020
the head bolt torque is 130 +or- 5ftlbs and as far as sequence if not sure start in the middle of the head and work your way out alternating side to side and in an X. Step up to 130 by starting at 80-100-115-130.
Nov 09, 2013 | John Deere 3010,3020 Tractor Basic...
My 1995 6200 John Deere is running hotter than normal. Done coolant flush. Blown out aircleaner, washed out radiator fins. Whats next?
IF YOU ARE NOT HAVING WATER BLOWING OUT WHEN YOU START IT IT PROBLEY NOT HEAD GASKET I WOULD LOOK AT WATER PUMP THE IMPALER COULD BE BAD IN THE WATER PUMP
Nov 10, 2012 | John Deere 6300,6300l,6400,6400l Tractor...
We have a 3020 john deere gas we just had head redone new head gasket put back together and only getting oil to half the rocker arms. took rocker arm assy back off and made sure holes were clear put back...
A couple of things should be looked at.
1. Make sure head gasket is aligned properly and not blocking any ports on the head or block. 2. When the head was milled debris may have been pushed into a port blocking flow, check for blockage. 3. When you replaced the head, did you torque the bolts in the proper sequence and to the specified ft/lbs?
Mar 26, 2010 | John Deere 3010,3020 Tractor Basic...
Hello, does anybody know the torque setting for the head bolts ona v-twin yanmar desiel engine fitted in a john deere 355. Cheers
Oct 28, 2009 | John Deere 4020 Gas & Diesel Tractor...
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
