Question about Samsung SCX-4300 Monochrome Laser Multifunction Printer
Where is the fuser and how do I remove it ?
I don't know how to remove the fuser
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Samsung Expert
  • 167 Answers
Open thru back cover
Posted on Oct 02, 2015
C-0500
Remove the fuser unit and verify the fuser heater lamp continuity and the thermofuse continuity.To reset the trouble code please tell me the copier model.
Apr 03, 2013 | Konica Minolta Office Equipment & Supplies
Fuser error
Your machine is in need of a new fuser unit. HP LaserJet 2400 Maintenance Kit Installation - Fuser (Part 1 of 2) Installing the fuser. Turn the power off and unplug the printer. Wait 20 minutes for the printer to cool.
Open the back door of the printer, using enough force that the door opens completely and the hinge locks disengage, as shown below.
2400_openbackdoor.jpg Remove the 2 screws circled in red below.
2400_removebackscrews.jpg Close the back door, and then flip the printer so that it rests on its face. 2400_closebackdoor.jpg 2400_flipprinter.jpg
Next swing open the paper guard which shields the back of Tray 2 when it is installed.
Looking inside the Tray 2 cavity, use a flatblade screwdriver to release the two tabs--one on each side of the rear cover.
Next remove the rear cover from the printer by pulling down and away.
Fuser Installation Continued . . .
Pry the grey DIMM cover loose and remove it.
Use a small flatblade screwdriver to disengage the tab on the connector shown below and unplug the connector.
Next (on the right hand side) remove the small black plastic cover, located near the green fuser gear, which hides the other fuser wires.
Then unplug the two connectors shown below and free the yellow/white wire from its guide clasp.
Now remove the four screws holding the fuser in place (shown below).
Now remove the black plastic piece shown below, the duplexer inlet guide. Gently pry the tabs on both ends loose and slide/rotate the guide back towards the fuser to release it.
Now you can remove the fuser, just pull it straight out towards you. Don't install the new fuser until you've replaced the main motor gear, as shown below.
Replacing Fuser Drive Gear
With the fuser removed, look into the printer and locate the main fuser drive gear on the left side of the fuser cavity (gear circled in red below).
Use a flathead screwdriver to pry the gear's release tab and remove the gear by sliding it off its metal bar.
Slide the new gear onto the metal bar--make sure the gear's release tab faces outwards so it will be accessible again--and lock the gear firmly in place.
Now repeat the fuser removal process backwards as you install the New Fuser:
Insert the new fuser and replace the four fuser screws. Replace the black plastic duplexer inlet guide, making sure both tabs click in place. Re-plug the single connector on the left side, and the two connectors on the right side. Replace the wire cover on the right side. Reinstall the DIMM cover. Finally, replace the back cover with its screws.
This is a difficult installation which should be done by a technician. Good luck with it !
Sep 23, 2011 | HP LaserJet 2420 Printer
Hi, my printer does not print and on display gives me error 77 i don't know if this is worth to get it fix or jus get a new one if u can give me some help? Thanks Al.
You are probably getting errors 76,77 and 78. All of which point to a fuser fault. The 9070 is a great machine and i would certainly get it repaired. in fact the fuser is easy to change. Open the main cover and it is at the front of the machine. Its the long black covered part with yellow writing on it warning you is maybe very hot. there are just two screws at each end to remove. Lift and the fuser will come out. Be careful as there are wires under it that need to be disconnected. Repair is just a reversal of the above.
Jul 05, 2011 | Brother MFC-9070 All-In-One Laser Printer
Hello i'm french, i have an oki c 8800 with : service call 173 fatal error. i don't understand what is this error and i want to know how to repare
Error code: 173
This error code means that the fuser temperature is low. You need to replace either the fuser or the thermistor inside the fuser.
May 27, 2011 | OKI C8800dn Led Printer
I getting 50.2 fuser error in hp laserjet printer what i do i don't know can u any one help me
the 50,2 error is a fuser error, and should be serviced by a repair facility. You can try to replace the fuser yourself, but the labor should be pretty cheap compared to the cost of the fuser assembly.
May 06, 2011 | HP LaserJet 5100tn Printer
Problem
You don't unless you happen to be a service technician.
The fuser is one place where you can get hurt playing around.
Also, most manufacturers will treat fuser id as a proprietary and you have to know the fuser id to change the data field.
Don
Feb 19, 2010 | Konica Minolta bizhub C351 All-In-One...
The printer display says "Open Heat Error". What is this and what causes it?
I'm not real sure but I do know the the fuser area contains heat sensors. If the fuser temp is higher than it should be, you will get over-temp errors.
Get the printer serviced. It very well could be a motherboard failure or a fuser control card.
Don
Feb 18, 2010 | Dell 1600n All-In-One Laser Printer
Re: Removing the upper fuser roller assemble.
if it is a repair manual it will have a diagram if it is owners manual it will not
Jan 18, 2009 | Office Equipment & Supplies
Samsung SCX-4300 Monochrome Laser Multifunction Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
