Question about KitchenAid Pasta Roller / Cutter Set
Spaghetti cutter not cutting kitchenaid - KitchenAid Pasta Roller / Cutter Set
2 Suggested Answers
  • 899 Answers
SOURCE: KitchenAid KP2671 - Spaghetti cutters stopped turning. Makes loud noise.
this is common for any device that has a motor,either the gears are grinding or the motors contact brushes need replacing, it will have to be looked at to determine the exact cause
Posted on Oct 13, 2008
What is the thread size on the knife cutters of the Kitchenaid KSB555.
The thread that the driving clutch screws onto measures 6.2mm with my calipers measuring the thread. Confirming it is left hand thread.
Aug 25, 2015 | KitchenAid Blenders
Broken input shaft
KitchenAid doesn't sell any internal parts for the KitchenAid pasta attachments, the only thing to do is buy a replacement, if it is just the pasta roller you can purchase the KPSA, if not the others are just sold in the KPRA pack
Mar 07, 2014 | KitchenAid Kitchen Aid KPRA Pasta Sheet...
My Marcato linguine cutter attachment is not cutting through. Can I adjust this?
These are notorious for the issue! If you can find a machine shop or maybe someone that repairs machines, such as a sewing machine, they may be able to adjust it. It just cannot be done by a regular unskilled person. Good Luck!
Nov 02, 2013 | KitchenAid Pasta Roller / Cutter Set
Where can i get gears for kitchenaid pasta roller
Not a solution, just want to echo the problem. There are solutions for the shaft, but when I opened this up I found a stripped nylon gear attached to the shaft. Kinda sucks: I recently replaced the nylon worm gear in the mixer, now I have to do the same in the spaghetti cutter. I can't find the part or any mention of it anywhere.
Jan 17, 2013 | KitchenAid Pasta Roller / Cutter Set
I got the brush stuck in the spaghetti cutter attachment. I turned off the machine but we can't get the brush out.
I had the brush get stuck in my spaghetti attachment and the attachment would not turn. My husband got out his drill with the smallest bit & he drilled a hole through the teeth of the spaghetti attachment & the bristles fell out. I can now make spaghetti once again.
Aug 08, 2011 | KitchenAid Pasta Roller & Cutter Set...
I have a KitchenAid KMT223 that I want to disable the beep. Can you help
You need to disassemble the toaster by removing the bottom part and reach the electronic board. On the board their is a micro speaker. By the use of a cutter just cut the one of the two cable connecting the speaker.
Now the toaster will mute.
If you decide later to work the beep just connect back the speaker.
Mar 12, 2011 | KitchenAid KMTT200OB 2-Slice Toaster
Have kitchenaid undercounter ice maker, came with the house i bought a year ago. the problem is the water freezes in the resevoir. i have replaced the circulating pump, the thermistor, some sensor,...
on the right side of the ice bin and above the cutter grid are 2 sensor plugs, unplug the one towards the rear of the machine (usually has light brown w/red striped wires). if this does not fix the problem then replace the main control board and the transformer. Also the water doesn't go to the grid, it rolls across the evaporator, freezes a slab of ice that then slides down to the cutter grid. the cutter grid should be somewhat warm, it is what cuts the ice into the little squares. I've worked on these machines for around 7 years now and have only seen this problem once, this should fixya
Mar 02, 2011 | KitchenAid KUIS18NNT 18" Automatic Ice...
Ice jams in KUIS18NNJB Kitchenaid under counter ice maker
There are 2 sets of wires on the cutting grid that are perpendicular to each other. Electrical current passing through the wires creates heat that melts the ice. The first set cuts one direction, then the ice strips drop onto the second set that cuts the strips into cubes. Remove the cutter grid and check if the wires are broken. If they are, electrical current can't pass through the wires, so no heat. Restringing kits are available to fix this. If the wires aren't broken, you'll need a voltmeter to see if current is reaching the wires. If it isn't, then the transformer has likely failed.
Dec 13, 2008 | KitchenAid KUIS18NNT 18" Automatic Ice...
Oct 13, 2008 | KitchenAid KP2671 Professional 6 Series...
KitchenAid Pasta Roller / Cutter Set Logo
151 people viewed this question
Top KitchenAid Kitchen Appliances - Others Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a KitchenAid Kitchen Appliances - Other Expert? Answer questions, earn points and help others
