Question about Frigidaire GLER341A Electric Dryer
How to fix Frigidaire GLER341A hums and vibrates when hot?
  • Frigidaire Master
  • 5,323 Answers
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
Posted on Apr 22, 2015
Frigidaire GLER341AS1 TOP OF DRYER GETS HOT
It is using heat to dry clothes, this is normal.
May 25, 2012 | Frigidaire GLER341A Electric Dryer
Drum won't engage. Switch hums, does not engage.
Sounds like a broken belt, or a broken (loose) tension spring.
Feb 10, 2011 | Frigidaire GLER341A Electric Dryer
Dryer does not start when I push the on button the motor hums.
If the motor continues to hum afteer letting go of the button, then it is likely a broken drum belt. If the motor hums but stops when you let go of the button, something is preventing it from turning. This could be a seized motor or a drum that is stuck, or something caught in the fan blade.
Nov 28, 2010 | Frigidaire GLER341A Electric Dryer
When Turned on, drum will not spin?
if the motor is running,your belt is the problem.if all you hear is a slight humming noise,you may have a bad motor,or something caught in blower. if the drum turns easily by hand,its probably the belt
Mar 05, 2010 | Frigidaire GLER341A Electric Dryer
When I turn the start knob on my Frigidaire Gallery Model GLER341A52 the motor makes a humming noise but nothing else, when I let the knob go it stops. The drum never turns or blower doesnt start it sounds...
Wow, different person, different dryer, same problem, same day. I went and got a complete new motor assembly for $170. I hooked it up, and it is still doing the same thing. So obviously that is not the answer. What did you find?
Nov 19, 2009 | Frigidaire GLER341A Electric Dryer
Model#GLEQ642AS2
If the drum is not turning and the hum is a nice quiet hum, then the belt on the drum has broken. The hum you hear is the motor turning without the belt.
If this helps you, please select YES to one of the first two ratings questions. Thank you, and Good Luck.
Aug 17, 2009 | Frigidaire GLER341A Electric Dryer
My dryer won't turn on.
When I flip the start button, it hums but will not start.
Aug 04, 2009 | Frigidaire GLER341A Electric Dryer
Back of dryer gets hot
id say your limit switches arent working correctly
Jan 14, 2009 | Frigidaire GLER341A Electric Dryer
Frigidaire GLER341A Electric Dryer Logo
63 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
