HP OfficeJet 7310 All-In-One InkJet Printer Logo
A
Anonymous Posted on May 05, 2014
How to repair print error
0x04464dd6
1 Related Answer
Anonymous
  • 4 Answers
  • Posted on Nov 19, 2008
SOURCE: error message
same problem. tried everything from hp, no good. finally figured it was alignment of cartridge problem, maybe because spring underneath, wasn't doing it's job. anyway, when inserting the cartridge, i put one finger underneath the cartridge and held upward pressure, while closing the green plastic cover on the color cartridge. problem fixed. the pins on the cartridge and the pins on the printer where not aligning properly by just slipping the cartridge in and closing the plastic cover.
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Canon mx922 error message needs repair
It is likely that the print-head temperature sensor is detecting an over heat. If that is the case, start thinking about a replacement machine as the printheads are expensive to replace.
My HP Office Jet won't print the entire document sent to it when it is asked to print double sided. And repeatedly will fail at the exact same spot in each document; although the spot where it fails is...
There are 3 step to repair 1018 error
If you got 1018 error then there is a 94% chance that your computer has registry problems. To repair 1018 error you need to follow the steps below:
* Step 1 - Download a Perfect Optimizer,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair 1018 error.
Here are the url of Perfect Optimizer:http://www.pcerrorremover.com/tidpp-1018...
Won't print. Green Light Flashes.
Waste ink absorberfullor platen waste ink
absorber full Pressing the OK button
will clean the error, and
enable to print.
In repair,
<Replacement of Ink
absorber kit
<Replacement of Platen
waste ink absorber
Waste ink absorber full
warning (service call
error) may appear.
14helpful
Brother MFC-9440CN error 5A print unable
Error 5A unable to print is a problem with the high voltage power supply PCB, or with the engine PCB. A shop could tell you which one after some testing. Expensive repairs...
Intrnal error
If you got c0000005 error then there is a 94% chance that your computer has registry problems. To Fix the problem you need to follow the steps below:
  • Step 1 - Choose a c0000005 error repair tool,download and install c0000005 error repair tool Scan for FREE.
  • Step 2 - Click the Scan Button.
  • Step 3 - then click the Fix Button and your done! It is very easy to repair c0000005 error.
Q: Which C0000005 Error Repair Tool is the most effective? A: The results of our research and rigerous testing procedure found that Perfect Optimizer was the most effective c0000005 error repair tool. Its easy to use, eliminated all known errors on our computer, includes great safely features and left our PC running incredibly fast. We were extremely impressed! Second came RegCure which was very user friendly, but did not perform as well in tests. Third came RegistryEasy.
Click Here To Download Our Winner C0000005 Error Repair Tool "Perfect Optimizer":
Printer Error Message
You need to replace the CARTRIDGES and if that does not help then need the servicing of the printer as the dock the print cartridges are seated have gone bad :(
Sorry this is 94% a Hardware problem
2helpful
3answers
Error message
My printing stops and I get this error message Error-0x07a74dd6 1959:lib_barracu.
What is the meaning to this and how can I fix the problem?
4answers
Error message
I am prining envelopes and got this message twice so far. I just unplugged the printer for a hard boot. Wish someone knew what generates this message though. Annoying.
k24674
Grand Canyon Tech
Grand Canyon Tech
