Question about HP 417035-001 - HP Pavilion dv2000 Series Laptop Full Featured Intel Chipset Motherboard
The Laptop Powerup no display in dv2000
When i turn it on, the power is comming, LCD is dull, some times its fine, Now its doed not comming any pre-boot writing messege. The i Plug in VGA its working fine, Please Help me, which once is defected converter or whole LCD?
  • zocop Jun 23, 2009
    dileepkumar2 Display is Nvidia, but no display in pre-booting, i think not need driver in pre-booting
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 52 Answers
Since you can view the laptop's output through VGA, it indicates that the issue lies with the laptop's LCD. As u mentioned, firstly the LCD become dull, and now it completely dead, suggest that the internal flat ribbon cables that connect the LCD to the motherboard of your laptop may have been damaged. This could happen sometimes after extensive use. Please get it checked with authourised technician. Do not experiemnt further, as this could make the situation worse. Cheers..
Posted on Aug 10, 2009
Blank display on HP dv2000 laptop
i suggest you dismantle your laptop and take a look at the LCD cable behind the screen and make sure it is click locked.
Jan 23, 2013 | HP Pavilion dv2000t Notebook
Hp pavillon dv2000 line on computer
Find out if the problem is the graphics chipset, or the LCD screen.
Laptop OFF, monitor OFF, plug a VGA monitor into the VGA port on the Pavilion dv2000 series of Notebook PC.
1) The VGA port is on the back of the laptop. Looking at the back of the laptop, it is the second port from the Left.
Example of a VGA connector, (On laptop it is a Port), and a VGA cable,
http://en.wikipedia.org/wiki/VGA_connector
The VGA monitor can be a CRT, (Looks like a small TV), or a flat LCD screen monitor with a VGA cable.
The VGA monitor will now just be referred to as External Monitor.
Monitor plugged into the laptop, turn the monitor on. Wait a few minutes if it is a CRT monitor.
Turn the laptop on.
The external monitor should automatically show the graphics of the laptop.
If not press, and hold down on the Fn key, (Bottom row of Keyboard, second key from the Left. The Windows key is to the right of it ), AND at the same time tap once on the F4 key.
If graphics do Not show up on the external monitor, press, and hold down on the Fn key, and tap the F4 key once more.
[ Your laptop has at least three functions for this Hotkey. (F4)
{Also known as Display Toggle-Over key}
1) Laptop internal display Only.
2) Laptop internal display, and external display. (In this case, a monitor. A Projector can be connected here also)
3) External (VGA) monitor Only ]
A) Does the external monitor have this line going through it also?
Yes? Problem is with graphics chipset.
B) No? Problem is with screen Inverter, or LCD screen.
Primer:
An LCD screen cannot produce light by itself. It needs an additional light source.
A Backlight is the additional light source.
A Backlight is a CCFL.
Cold cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
A screen Inverter is a small circuit board that converts the electricity from the laptop, for the Backlight, and LCD screen.
(Too broad a statement. There are some laptops that their LCD screen, does not receive power through the Inverter. Their power is derived from the Video Cable only )
90 PERCENT of the time the fault is the Inverter
This is an example of a screen inverter, for an HP Pavilion dv2000 series of Notebook PC,
http://www.nylaptopparts.com/index.php?main_page=product_info&cPath=91_96&products_id=200
Click on the image to enlarge. (Size is approximately 1/2 inch tall, by 4 inches long)
Make a mental note of the price. This is an average price. You may also find a better price.
This is an example of a replacement LCD screen,
http://www.laptopscreen.com/English/model/HP-Compaq/PAVILION~DV2000/
A1) Without a sensitive multimeter, (Read expensive), you do not have a way to test the Inverter.
IMHO I would replace the screen Inverter, and see if this repairs the problem.
If it does not, then an LCD screen replacement is next.
B1) If the line is on the external monitor, you have a graphics chipset problem.
With most laptops a motherboard replacement is the easiest option, however it is the MOST expensive option.
It has been found that the HP Pavilion dv2000, dv6000, and dv9000 series of Notebook PC's, have a graphics chipset problem.
It isn't the graphics chipset, per se, it is the mounting of the graphics chipset to the motherboard, AND the inefficient cooling for the graphics chipset.
Primer:
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_circuit
The graphics chipset is the GPU. Graphics Processing Unit,
http://en.wikipedia.org/wiki/GPU
Use GPU-Z to find out what exact GPU your laptop has.
I do know that it uses Intel GMA 950 for graphics, which is usually paired up with one of Intel's Core2 mobile chipsets,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Core.2FCore_2_mobile_chipsets
The graphics chipset is mounted to the motherboard with a BGA surface mount.
Ball Grid Array.
To explain a BGA surface mount, let me compare it to the Intel Pentium 4 processors, that used a Socket 478 processor socket.
The bottom of the Processor has contact pins. 478 of them.
The Socket 478 processor socket has 478 socket holes.
With a BGA surface mount, there are no contact pins, and no socket holes.
Solder Balls on the bottom of the graphics chipset, take the place of the contact pins.
Copper Pads on the motherboard take the place of the socket holes.
When installed by the factory, the graphics chipset is set into place on the motherboard, so that the Solder Balls are lined up with the Copper Pads.
The chipset is heated to a specific temperature, for a specified length, and the Solder Balls melt.
The solders the chipset to the Copper Pads. Solders it to the motherboard.
IF, the graphics chipset repeatedly overheats, the solder connections are partially melted, and this makes a bad contact. (Contacts)
A video I found that explains the above in more depth,
http://www.youtube.com/watch?v=bnkQNmKauEc&feature=pyv&ad=5823851286&kw=DV2000
(NOT advertising for this guy, just inserted for the information, and video )
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 10, 2011 | Compaq Presario M2000 Notebook
Laptop Hp DV2000 Display Problem
Thirty days, it should still be under repair warranty.
Feb 28, 2010 | HP Pavilion dv2000 Series Laptop Full...
I bought a new hp dv2000 laptop 2 yrs back. till date it was working very fine sudenly yesterday morning when i powered on the laptop thin lines appearing on the screen display... i tried to on the system...
honestly the problem is in your lcd display. it is already defective lcd. replacement of lcd is much expensive. it would be better to buy a new unit rather than replacing the lcd.
Feb 08, 2010 | HP Pavilion dv2000t Notebook
Hp pavilion dv2000 no lcd dispaly - FixYa
Try this:
first, shut down your computer.
then, take out the battery and ac plug.
third, pres the power on button for 30 seconds
next, plug in JUST your ac plug and try turning your laptop on. If the lcd still does not, try with the batteries, but no ac plug.
Jan 31, 2009 | 2003 Lexus IS 300
Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information
This issue can be caused by any of the below situations.
  1. New hardware conflicting with old hardware.
  2. Bad or failing hardware device.
  3. Connections not connected or connected properly.
  4. Recent electrical storm that caused a surge that damaged computer.
  5. Other hardware issue.
Sep 24, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP Pavilion Dv2000
on your display properties, switch windows to appear on your laptop. and do not connect your LCD when booting your PC. there is an option in display property that says extened your windows to this display... that is your LCD.
Apr 10, 2008 | Acer TravelMate 2300 Notebook
Lid switch location??????????
HP DV 5000 LID switch location is here:
If You want test lid switch, just connect A+B together for a monent!
If the monitor flashes on...? Lid switch is faulty.
It is too dificult to change the lid switch, so the easiest way is connect these pins together forever. :))
Dont forget to turn off your notebook... he wont sleep anymore ;))
Greetings from Latvia.
lauris@bttehnologijas.lv
Feb 01, 2008 | HP Compaq Presario V5000T Notebook
Acer aspire 3680 MONITOR backlighting problem.
its u r laptop lcd problem.so please replace u r lcd
Jan 11, 2008 | Acer Aspire 3680 Laptop
HP 417035-001 - HP Pavilion dv2000 Series Laptop Full Featured Intel Chipset Motherboard  Logo
240 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
