Question about Marantz Audio Players & Recorders
Marantz pm 673
Hi , No sound .Source does not matter . I have no schematic . power supply ??
  • Marantz Master
  • 3,368 Answers
I disagree without a source this is what you would get, no sound.
Contact the manufacturer or try an on line search with Google!
Posted on Nov 27, 2014
jedimazter
  • 7 Answers
SOURCE: marantz pm 7200
Could be a power supply failure or a Power "On" switch failure.
Kev
Posted on Feb 24, 2008
SOURCE: marantz PM-74D
Your no doubt finding the speaker safety/turn on surge protect relay NOT engaging a few seconds after turning it on-right? Check the output transistors. These are the big green and black ones screwed to the heatsink. You gain access to them by taking off the bottom cover. There's 4 per channel--2 green and 2 black. You'll probably find one or more of them shorted. If you find replacements, put them in exactly as the originals with new thermal grease/heatsink compound. Unsolder and lift the center pin (collector) on each of the four transistors of the effected channel. Power it up and check across the outside pins of each device for proper bias-about a half a volt or so on each one. If the voltage is much higher, or not there you've got other problems that will require more diagnostic/troubleshooting. Do all the lights on the front panel work-or just the tape monitor indicators? If just the tape monitors light up, check resistors RN83 and RN84 on main board under the speaker connector board-remove the speaker connector board to get at them. These are bad on mine and I've yet to replace them. I believe these to be 920 ohm 1% precision resistors....
Posted on May 26, 2008
SOURCE: Marantz PM 4000 has cut out
May be the problem solved here :
http://www.audiotoolers.com/ubbt/ubbthreads.php/ubb/showflat/Number/5316/page/1#Post5316
Posted on Dec 04, 2008
mikeymiddles
  • 58 Answers
SOURCE: marantz pm 7200 integ.amplifier
Dear Sushant,    I do not think your use of an equalizer has caused any problems.  I will explain the proper use of the source/direct button.  This button's function is to monitor the output of a recorder connected to the record outputs of your amp.  When this button is pressed on the sound going to the speakers comes direct from the "source" (cd, radio tuner, phonograph etc.) when in the off position you can monitor the recording of whatever source is being recorded via the tape deck.  This switch must be off to record through the amps record outputs.    To test this, put a blank tape in the tape deck, choose the source as phono and place the dec in record/pause.  With the source direct button pressed on you should hear a change in volume when moving the amp's volume knob only.  When source direct is off you will be able to hear the output of the tape deck, so adjusting the tape deck's record level will also affect the volume coming out of the speakers.  more record level in/ more level out.!    Below is copied from page 9 of your user operation manual for Marantz's explanation of the source/direct button.  image.tiff
best of wishes, Michael Mittelsdorf
Posted on Jan 05, 2009
  • 226 Answers
SOURCE: marantz pm 550 dc, service manuals and schematic
Hi,Give this a try. I think it is what you are looking for.
http://www.eserviceinfo.com/download.php?fileid=48367
Click where it says "Download >> To download the file, please, click here
It's a multipart file, so you need to download Multipart 0,1
open it using winrar and the open it to view the pdf file.
Note: you must have a pdf viewer to read the file.
If you need anymore help with the amplifier, then please ask.
Regards - Anthony
Posted on Feb 28, 2010
Servo stabilizer
A high quality fast response Servo Stabilizer will solve the problem but mark my words highlighted
Mar 12, 2015 | Marantz Audio Players & Recorders
Marantz pm 520 dc, service manuals and schematic diagram
As a former authorized service center for Marantz in the 80's, I probably have the manual for a cost.
Apr 28, 2014 | Marantz Audio Players & Recorders
Can I replace the stock power cord on my Marantz PM-11S1 integrated amp. with a new high end power cord ?
Hi Nancy,
Yes you can replace the power cord if it is already defective(open internal wire). You may buy on your local electronics store. But if the power cord is in good condition, there's no reason to replace.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Feb 16, 2011 | Marantz PM-11S1
Marantz pm 15 s1 amplifier and marantz sa15 s1 Cd player
There really is no point in  connecting the two components with an optical (=digital) cable, if you didn't want to use the SA-15s DAC- and analog output section you might aswell have bo bought the chiepest one you could find...
To get better sound than the SA-15s analog outputs can provide, you would have to spend a load of money (not as much as for the SA-15 but quite a bit) on a DAC - and the DAC would only work with CDs, you would still have to use the SA-15s analog outputs to listen to SACDs.
So in conclusion:
-Use the SA-15s analog outputs
-If you have other digital sources that you want to use - if you care about their sound quality - you can sell/return the SA-15s, buy the chiepest CD-Player you find (only look and feel matter) and spend the rest on a good DAC. (note: SACDs won't play on this setup)
I'm using a PM-15S1 with a DAC (Apogee Mini DAC, Studio-Equipment, nominal price ~1000$, got mine 2nd hand for 400€ ) myself. A DAC is usually the better choice over an expensive CD-Player - especially if you've got other digital sources (PC, ...) - but you'll probably lose a lot of money if you sell the SA-15, so think about it (IF you're still thinking about it, I realise that your question is 8 months old...)
anyway... have fun with the PM-15, it sure is beauty
Jan (Hamburg, Federal Republic of Krautistan)
Jul 01, 2009 | Marantz PM-15S1 2-Channel Amplifier
Sound from left channel is small and distorted.
The distortion might be caused by a resistor. The loss of volume could be the capacitors, but you could try injecting signals into the transistors to see if any has gone. They can cause the distortion and loss of signal. If you apply a soldering iron to any part it will heat up quicker, or you could also use a hairdryer for the whole thing. You can also get a freeze spray that cools things that have heat sensitive faults (available from electronic parts shops).
Apr 24, 2009 | Marantz PM-15S1 2-Channel Amplifier
Marantz pm 7200 integ.amplifier
Jan 05, 2009 | Marantz PM7200 2-Channel Amplifier
PM-68 Marantz Receiver keeps shutting off sound after a few
try turning the system on with no speakers hooked up. and see if it clicks off. if it does,the problem may be the a short on the speaker connections.
Dec 24, 2008 | Marantz PM-68 Amplifier
Nov 21, 2008 | Marantz Audio Players & Recorders
Marantz PM-48 connecting to TV
look on the back of the TV and there should be L/R audio outputs (white & red), connect this to a spare input of your amp via a connecting lead eg. AUX or any other input except PHONO.
hope this helps.
Oct 19, 2008 | Marantz PM-68 Amplifier
Marantz pm 7200
Kev
Feb 23, 2008 | Marantz PM7200 2-Channel Amplifier
149 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
