Question about Bosch AHS 52 ACCU Cordless Hedge Trimmer
Battery runs out in 5mins
Charge battery for 1hour
Zoomerpup stopped working
Try removing the battery ONLY for about 5mins. Then reinsert the battery and see if it powers on.
If that fails, remove the battery AND Media Card for 5mins. Reinsert battery first...power on. Then SD card.
If neither of those work, check charger to see if it is working. If there is an LED light on the actual charger, this should light up. If there isn't, then the charger should at least be warm after say, 30mins of charging. If it is still cold, you may need to replace the charger.
Nov 25, 2013 | Toys
Battery won't charge
connect the charger to the socket, then connect the charger to your laptop. if it does not charge remove it for 5mins, connect the charger back. it will work now. sometimes when the battery is fully charged and you remove the charger and connect it back it may not charge until the battery is low;lets say 99%.
Sep 23, 2011 | Advent 4211c Notebook
NC10 battery not charging. The charging light flashes as normal but battery wont charge, tried another battery with same result.
Allow 1hour to charge it, if did not charge check the input & output of the charger if its properly insert, if not again off your notebook & charge it, always check if it is charging,
Note: Charging test try on, off, & unuse it allow to full charge the battery before using..avoid low bat your battery when using.
Jun 03, 2011 | Samsung NC10-14GW Notebook
How much time should a iQ sound mp3 player charge
MY IQ SOUND MP3 ONLY STAYS CHARGED FOR 5MINS,I PLUG IT IN TO CHARGE AND INSTANTLY IT SAY BATTERY FULL BUT ONLY LAST AGAIN 5MINS,ANY IDEAS.
Dec 05, 2010 | Bell Technology IQ Sound SC-2528 MP3...
My laptop Battery life span is Only 1hour and 10mins either in 100% fully charge. My Computer model is Sharp Pc-fw50x. battery model aha441203070812012fc.
Please refer to the following article about laptop battery problems:
http://www.fixya.com/support/r6416355-troubleshooting_laptop_battery_problems
Normally, laptop batteries lose capacity, whether you use them or not, at a rate of 15% or 20% per year. Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Oct 21, 2010 | Computers & Internet
Battery flat, not charging. Jump started bike off car - no probs, let it run for 20 min, turned off and tried to re-start, nothing. Dash and headlights don't even come on.
The best thing to do is chk your charging system at the batt terminals w/engine running. The charge rate should be between 13,6 - 14.2 volts. THE HIGHER THE VOLTAGE, THE LOWER THE AMP S. iN TURN , LOWER VOLTS MEAN HIGHER AMPS. iF IT IS CHARGING AT 13V OR LOWER THE BATTERY IS NO GOOD. iF VOLTS ARE HIGHER THAN14.2V, tHE ALTERNATER IS BAD. Often a battery can be saved with a trickle charger, charging at a very low rate over a 48 hr. period. If the Alt charges at substained high output it can overheat and fail. Motor cycle alts. rarely fail because the engine oil removes the heat. So, Chk the battery fluids, slow charge for 24 hrs and repeat the voltage chk. _Good Luck_Ned_
Nov 01, 2009 | 1994 Honda CB 250 Nighthawk
Less battery backup
Hello Sir,
Please have a search in Google for a utility for battery (Battery Rebuild And Maintenance.jar) or (battery.jar) . If you can't find these let me send you.
Regards
nidostyle
Nov 16, 2008 | Sony Ericsson w580i Cellular Phone
Bosch AHS 52 ACCU Cordless Hedge Trimmer Logo
Top Bosch Garden Experts
roeb
George Merkley
George Merkley
Are you a Bosch Garden Expert? Answer questions, earn points and help others
