How to sync a wireless mic to a Samsung CR 77 UHF
2 Suggested Answers
  • 5603 Answers
SOURCE: Where can I get replacement antennas for a
These will work:
http://pro-audio.musiciansfriend.com/product/AudioTechnica-ATWA3-Antennae-Pair?sku=275058
Posted on Jan 04, 2010
We have a wirless Microphone using with a xp510i itwas working OK but we think somepne has played with the knobs as I cant get the Mic to working through the speakers any ideas
Process of elimination needed. Plug a corded mic into the wireless channel. Does it also cut in and out? If not then it sounds like the wireless is the one cutting in and out...not unusual for cheap units. Your wireless is not a cheapie? Then check the wireless squelch setting located on the receiver as it may be set too high.
Apr 25, 2014 | Samson Airline 77 Aerobics Wireless...
How do i sync my mic to my receiveri have a ew 100 g3 and after some kids were playing with it, I can't get any sound
Pressing the sync button whilst holding the mic close to the IR unit on the receiver should sync things back up. If this has already been done things to try next are as follows.
RF Mute. Press and release the power button. RF Mute should be displayed. Press the roccker switch and select RF mute OFF, press the rocker switch again.
Check in the advanced menu that the pilot tone is on on the handheld AND the receiver.
Jan 23, 2014 | Sennheiser Evolution G2 100 Series UHF...
I Have 2 recivers and 4 mics but can't use all 4 only 2 works
A wireless mic receiver will only reliably work with one mic at a time. For that reason, you need to have 4 receivers in order to use 4 mics simultaneously. You could switch back and forth between mics by setting them to the same frequency and turning them on and off, but they will not work reliably if they're both on at the same time.
Nov 10, 2013 | AKG SR40 - UHF Receiver SR4054 Microphone
No sound Samson airline 77
So, if I am understanding you right. As you are talking on the mic you are cutting out as if it is shutting down. If this is the case I would adjust your settings. It sounds like it is clipping from maxing out the input. A protection is cutting you out. Let me know if this is not the case.
Jan 20, 2013 | Samson Airline 77 Professional Microphone
With the -10dB pad setting, still get distortion with loud singers using SLX Wireless Microphone. Need a mod to say -20dB pad. thanks
Yes I have this exact problem myself. Work for nightclub and our original Shure wireless was fine and we replaced it with an slx. We have MCs that really yell into the mic. I'm gonna try and find an older 58 capsule to pit on it and see how that goes. The mic would probally be fine with normal singers.
Oct 15, 2010 | Shure SLX-2 Handheld Wireless UHF...
I bought a samson se50 headset microphone to go with my GTD Audio wireless system. It has the correct adapter plug to plug in to the transmitter. The plug is a mini XLR plug. The microphone does not...
You need power from the transmitter to power this mic. See your mics specs to determine if it needs "Phantom Power"
Perhaps the transmitter doesn't supply power. Condenser mics may not work. Stay with the dynamic type. IMHO
Jul 29, 2010 | Nady Systems Nady ATM-75 Headset Mic w/...
Change the samson airline 77 microphone for a AMT, for sax player
Unfortunately, you don't have enough information to go on to give you a definative answer.
The Sampson Aireline will plug onto ANY xlr type DYNAMIC mic and should work.
The one thing on the AMT Elite I found said it was a "condenser" type element which means it would NOT work with your Sampson setup. Condenser mics require a Phantom power arrangement to charge the element and operate the local FET input amplifier.
If you are trying to mic a violin, the Airline 77 that was for the dynamic mics is a very poor choice as it is low impedance. Most violin pickups use a Piezo pickup which requires VERY high impedance input amplifier.
For my wife's violin we use an Autolycus pickup and an X2 wireless sytem. The pickup comes from New Zeeland and the X2 is CD quality digital wireless link. You have to make your own connector at the violin for the X2 cable was intended for guitars.
Dec 21, 2009 | AMT Datasouth Violin, Viola, & Mandolin...
Shure wireless UHF microphone
Make sure the microphone and the receiver are still broadcasting/receiving on the same channel.
Check that all of the appropriate connections are right from the receiver to the mixing board are connected as well.
I hope this helps!
God Bless you!
Oct 17, 2008 | Dual Pro2- WM795V Channel VHF Wireless...
MY JOB DEPENDS ON THIS!!! SONY DSR PD170 AUDIO PROBLEMS
Appreciate the direct "Ask Me".
The Sony PD170 is not an everyday equipment, nonetheless, I will assume that on the Sony DSR PD170:
  • the Samson UHF M32 receiver is plugged to Audio 1;
  • boom mic is plugged to Audio 2; (or vice versa) and
  • Both Audio 1 & 2 are using the XLR connectors.
Assuming that your boom mic is a conventional dynamic, on the Audio Control Panel, pls set:
  • INPUT 1 -
  • MIC CH SELECT CH1&CH2
  • INPUT LEVEL MIC
  • +48 OFF
  • INPUT 2 -
  • INPUT LEVEL MIC
  • +48 OFF
This is of course assuming that both the boom mic and the output of the Samson UHF M32 receiver are set to MIC level. In some instances the Samson UHF M32 receiver requires a LINE setting. The only time the +48 is set to ON is when the mic that is used/plug in requires phantom power such as condenser types. If the mic or the Samson UHF M32 receiver requires power then this should be switched ON otherwise, there will be no audio coming in. Though most M32 uses a 9 volts battery.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 11, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
 Grubhead
Grubhead
