Question about Vivitar Cameras
Can i use my vivitar 4600 with my nikon d300s?
    Novelist:
  • 193 Answers
Yes. You can use the flash in auto or manual mode by setting the camera to manual shutter speed within the x-sync range and then selecting the aperture prescribed by the flash guide number or the displayed automatic f-stop on the flash. The flash can provide auto exposure with the camera in manual mode, but you need to be aware of the amount of ambient light which will not cause any exposure corrections by the camera in this mode. Another alternative is to select Aperture preferred automatic on the camera and the f-stop shown for the auto flash settings. This will allow the camera to vary the shutter speed but may cause long exposures if the camera is not sensitive to real-time flash readings.
Posted on Jan 18, 2015
2 Suggested Answers
  • 48 Answers
SOURCE: Nikon D80. Vivitar 4600 Flash unit
That particular unit is probably not a good choice for the D80 because the trigger voltage (the electricity which flows from the flash through the camera circuits to fire the flash) is 19.5 volts, according to http://www.botzilla.com/photo/strobeVolts.html - this could possibly damage your camera electronics.
You don't have to stick with Nikon brand Speedlights, but get a modern flash which says it is I-TTL compatible for Nikon.
Posted on Mar 08, 2009
I need to convert a vivitar 28-200mm to fit a nikon d5000
You could buy one with Amazon for 11 dollar.
Be aware the lens is complete manual and possible very difficult to use, because toy have to set everything by hand. (lens and camera)
Vivitar T2 Lens Adapter Ring for Vivitar SLR Camera Lens to Nikon
Jan 15, 2014 | Vivitar 1.4X AF TeleConverter FOR NIKON...
Tip
My new 2month old..d300s..my if Switch Off it shows On..LCD goes Blank..no live...
DSLR Camera or All kinds of Expensive camera needed a good care.Otherwise it will effect by Fungus or Moisture cause the damage to your Camera.I Have a Tip to give you to Protect your Camera in inexpensive way.
Tip:Take a Cardboard Box ,cover your camera and lens with dry cotton cloth and put it inside the Box.Make a Coin size hole in any side of the box and connect a zero watts Bulb or Frigde lamp fix to the hole.(You should need only a Zero watts Bulb or Fridge Lamp)You can switch on the Lamp now.Another way is to buy silica and put it in your bag even if you travelling.Silica will obserb moisture and kep your camera dry.
on Oct 02, 2010 | Nikon D300s Body only Digital Camera
Nikon d300s
I've had this happen occasionally with my D-90. It has always been a problem with the battery not making proper contact. And, I've always been able to fix it by either reseating the battery or replacing it with a freshly charged one. It's possible that the battery is bad and may not be accepting a charge.
Nov 16, 2013 | Nikon D300s Body only Digital Camera
My nikon d300s will not come on
Hard to tell with this one, Would have to be takin apart to determined whats wrong
Nov 09, 2013 | Nikon D300s Digital Camera with 18-105mm...
Hi, I want to buy a remote shutter release for my nikon d300s. Do you have any recommendation?
Yes, buy it here at Continental Photo,XXX, ask for vic
digital wireless shutter release - 129.95 + 5.95 s&h within u.s.
wired shutter release - 29.95 + 5.95 s&h within u.s.
Order it over email or phone and pickup in store, no shipping fees.
5 Continental Avenue, Forest Hills, NY 11375
Jul 31, 2011 | Nikon D300s Body only Digital Camera
DOES IT WORK WITH NIKON D300S
Yes, though it's an older flash unit and cannot be used in the iTTL mode. The "Other Flash Units" section of the D300s manual (page 350 in my copy) lists the modes in which the flash may be used. Another concern is that the flash may not work well with certain lenses. The "Usable lenses and cameras" section of the SB-29 manual (page 5) discusses this.
If you need manual, you can download the D300s manual from
http://support.nikontech.com/app/answers/detail/a_id/16525/kw/D300S/r_id/116678
and the SB-29 manual from
http://butkus.org/chinon/nikon/nikon_sb_flashes/nikon_sb_flashes.htm
Jun 25, 2011 | Nikon Macro Speedlight SB-29 TTL Ring...
I took the memory card out of my coolpix 4600 and put it into a vivitar camera when i inserted the memory card back into my coolpix cannot get the camera to work or turn off
Did you take pictures with the vivitar camera and saved it on the same memory card? If so, that might be the problem. Delete those files taken by vivitar (copy them to your computer if it is important before deleting) then try the memory card again on your coolpix.
Jun 16, 2011 | Nikon Coolpix 4600 Digital Camera
Price for nikon d300
D300 can be found scarcely new. It has been replaced with a newer model D300S. The D300S incorporates video and both SD and CF capability for extended uses of writing the photos. One card can be used as backup, or one can be used to write RAW files and the other JPEGs. Some slight changes were added to the menu {active D-lighting}, and the D300S also was give a slight boost to 7FPS. Used D300 on the market go for $900 - $1300 depending on its history.
Apr 02, 2010 | Nikon D3000 Digital Camera
I just bought a D300s digital camera in Seoul yesterday and I'm unable to use it because the manual is in Korean. I'm Canadian and speak English. After spending over 2000usd, I am very disappointed in your...
1706b32.jpgNeed a spare battery for your Nikon D300s digital camera? Capture beautiful memories perfectly with a high capacity battery for your Nikon D300s digital camera. Rechargeable Li-ion 7.4V(Compatible with 7.2V) 1500mAh Nikon D300s battery for sale,20% off! 1 year warranty!
http://www.nikon-coolpix-replacement-battery.com/d300s.htm
Oct 02, 2009 | Nikon Cameras
Jan 01, 2009 | Vivitar 850AF for Nikon TTL Flash
Cameras Logo
81 people viewed this question
Top Vivitar Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
