Question about Rockstar Grand Theft Auto (GTA): Vice City Stories for PlayStation 2
How to fix create pixel shader - Rockstar Grand Theft Auto (GTA): Vice City Stories for PlayStation 2
Patch for running the game on pixel shaders 2.0
Unfortunately, the problem comes from your Video Card. This videogame requires a minimum of pixel shader 3 from your videocard. You probably have an older card which has pixel shader 2 or less... The only solution is to change your video card for one that suppors pixel shader 3.0...That's the only solution available to you!
Jun 29, 2011 | Capcom Devil May Cry 4
Unsupported pixel shader version detected.2.0 what does dis mean im having a graphic card Nvidia FX5200 what to do i want to play the game
This message might mean that the game requires a pixel shader more than 2.0 as the graphic card you have, got pixel shader version 2.0. A pixel shader is a type of program often used with games which allows your card to perform per-pixel effects meaning more pixels per second which increases the quality of the game. In this case Devil May Cry 4 uses high graphics and therefore a higher version of shader. You might wanna upgrade your card to Nvidia 8600gt or more to get better performance.
Hope this is helpful
Best regards
Oct 10, 2010 | Capcom Devil May Cry 4
Not able to play games on my laptop
Hello sir, hi, to have an idea of what is a pixel shader, visit this website:
http://en.wikipedia.org/wiki/Pixel_shader
Apr 27, 2010 | Acer Aspire 5500 5570-2609 Laptop
ERROR: Un supported pixel shader version detected, 2.0
You get this error because your graphic-card (architecture) is too old to run the game. To run the game you need a graphic-card which supports at least pixel shader 3.0, whil your card "only" has 2.1.
In case you're sure your card supports pixel shader 3.0, you'll need to update the graphic driver and/or DirectX (component of Windows) to the latest version(s) and try again.
If you're not sure wether your card support pixel shaders 3.0, you can post the brand, name and type of your graphic card here and I'll reply. When the card doesn't support 3.0, there is no other solution than simply buying a newer card (or don't play the game).
May 26, 2009 | Capcom Devil May Cry 4
Pixel shader
Your graphics card does not support the game. the only way  to fix this problem is to buy a new graphics card with newer shaders.
Mar 13, 2009 | Capcom Devil May Cry 4
What is pixel Shader ??
The Pixel Shader version on the Nvidia 6000 based videocards (6200, 6600, 6800 etc). you also need to ensure that directx 9.0c is installed to be able to use full features of pixel shader version 3.0
Feb 08, 2009 | Nvidia GeForce 6600 256MB 8X AGP Video...
Pixel shader
A pixel shader computes color and other attributes of each pixel. Pixel shaders range from always outputting the same color, to applying a lighting value, to doing bump mapping, shadows, specular highlights, translucency and other phenomena. A pixel shader alone cannot produce very complex effects, because it operates only on a single pixel, without knowledge of a scene's geometry or of neighboring pixels. A pixel shader is a computation kernel function. Pixel shaders can alter the depth of the pixel (for Z-buffering), or output more than one color if multiple render targets are active
Feb 02, 2009 | ATI RADEON X1650 Graphic Card
HOW TO GET PIXEL SHADER3.0
Pixel Shader 3 is a hardware feature. You can only get Pixel Shader 3 by getting a new graphics card, as it cannot be 'installed' with software. Please don't use all caps, it doesn't make people want to help.
Feb 01, 2009 | Generic Memory nVIDIA FX5500 256MB 8x PCI...
What is pixel shader
Here is the answer right of Wikepedia.
A pixel shader computes color and other attributes of each pixel. Pixel shaders range from always outputting the same color, to applying a lighting value, to doing bump mapping, shadows, specular highlights, translucency and other phenomena. A pixel shader alone cannot produce very complex effects, because it operates only on a single pixel, without knowledge of a scene's geometry or of neighboring pixels. A pixel shader is a computation kernel function. Pixel shaders can alter the depth of the pixel (for Z-buffering), or output more than one color if multiple render targets are active.
Nov 30, 2008 | Computers & Internet
Nvidia GeForce4 MX440SE 128 MB No pixel shader
Run the test below to see what you need to run it.
http://www.systemrequirementslab.com/referrer/srtest
pixel shader is built into the card so therefore a better card is required to play the game.
Jan 08, 2008 | Nvidia GeForce4 MX440SE 128 MB AGP Graphic...
Rockstar Grand Theft Auto (GTA): Vice City Stories for PlayStation 2 Logo
Top Rockstar Video Game Consoles & Games Experts
James Wishart
Are you a Rockstar Video Game Console and Game Expert? Answer questions, earn points and help others
