Question about Samsung CLX-3175FN Color Laser All-in-One Printer
I am using samsung clx 3175 and got a message that says " Main Motor locked". I opened all doors and closed them again but the message did not go away. I cannot print now. Wish you can help
anjana03
  • 361 Answers
SOURCE: samsung clx 3175 toner chip overide/reset?
we use chip and fuse for samsung cartage reset when it give us cartage empty message. before geetting thish we gets tonner is low .if recently we filled samsung dust/powder/tonner in cartage we no need reseter. in my practics while i need to put fuse (reseter) i put iton cartage after resetin suddenly i putout it from cartage and use old fuse. in this way we can use or not green chips? actuly it is difficult.
Posted on Jun 12, 2009
komguy
  • 2306 Answers
SOURCE: My clx-3175 wont print black and white when color
All of the manufacturers do the same thing to get people to buy their toners, if any toner is empty you don't get to print even black. Sometimes empty toner can scratch a drum so that's the excuse they use for making them that way.
Posted on Feb 05, 2010
rulds2008
  • 3866 Answers
SOURCE: I have a
Open the door and check the lever there is a little lever in ther that you need to push up if i remeber correctly now if you still get that message then you got a bad door sensor and those are tuff to handle you will need to contact samsung to have it looked at professionaly.
thanks hope this info does help please do leave feedback and ratings for your free answer today.
Posted on Apr 27, 2010
  • 553 Answers
SOURCE: I have a samsung CLX 3175 FW printer. Paper jams
The limit switches are just flags that block or unblock photo sensors. Try blowing the printer out with some canned air, paper dust on these sensors is a common cause of these problems.
Posted on Jun 23, 2010
Testimonial: "Thanks very much, I'll try that - I'd like to think it was as simple as that! Kind regards Ray"
  • 12 Answers
SOURCE: i am getting deve home sensor error on my samsung
Dev. Home error can be fixed by stretching out a solenoid spring on the power cord side of the printer. The solenoid acts as a clutch to stop the spinning developer actuator at the right spot.
The problem is that the spring gets weak over time / the cogs round out over time and the solenoid finger is overcome by the spinning cogs, and resulting in selecting the wrong developer.
Open up the right side (power cord side) of the printer (take off top cover, then take off side cover). Then, find a solenoid (little metal square) that touches the white plastic vertical spur gear. Take the spring off the solenoid. Now, put the spring back on - only this time you will attach one anchor point to the middle of the spring as to pre-stretch the spring for more tension.
More pictures of the solenoid on Facebook:
http://www.facebook.com/#!/photo.php?pid=55779771&id=2257206&fbid=10100154259704133
Posted on Jul 10, 2010
On a clx-6200 message says "paper jam 0-c=open/close door. what door is this?
It is telling you that there is a paper jam. Open the door, pull the jammed paper out, close the door, it should clear the message.
Apr 21, 2012 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX-3185
Hi
Have you checked the cartridges access door?
If so,try disconnecting the printer and leaving it for a long period [like 1hr] before connecting again.
Feb 28, 2012 | Samsung CLX3185 AllInOne Laser Printer
My Samsung CLX-3175 printer will not print - the message is replace/install toner waste bin. I have emptied the waste bin of all the ink and replaced it and still the message will not go. I have a stack...
open the cover and now remove the waist toner container (you say it is empty) check the conection to the drum unit sometimes if the waist toner is verry full there is a pille of toner closing this connection, now clean it and all the sorounding from the toner and mount the waist container back in his possition, close the front cover and try, it should work now.
Apr 27, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
Please some body can tell me how or where i can buy or the way to reset my samsung clx3175fn. It's not a good printer Jim
samsugn clx 3170/3175 not easy to reset but we have solution for refiller and recycle people install one modual or ic pritner work life time no need to again empty message
also we have software solutions save warranty.
www.chipresetters.com
mns:howtorefill@hotmail.com
+919825523201
Feb 24, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
What toner does the clx 3175 take. Does it use a chip as well - which one?
Takes CLP 310
To use Toner refill you need a chip that solder to the main board. search Ebay for reset chip for CLX-3175
run around $40.
Service Manual Free
http://hotfile.com/dl/28988134/55113fe/CLX-3170-3175.zip.html
Feb 12, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Sanner is locked!
Service Manual at
May 31, 2009 | Samsung CLX-3175FN Printer
Samsung CLX-3175FN Color Laser All-in-One Printer Logo
23 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
