Question about Honeywell Programmable Thermostat Heater
Thermostat won't work in cooling mode or fan ON mode
I installed a new Honewell RTH230B programmable thermostat last fall, and it worked through the winter fine. Now that I need cooling I can't get it to start the A/C. The fan will not run in the ON position, either.
I checked my wires against the board in the furnace (Rh to R, Rc to C, Y to Y, W to W, G to G), and re-connected all terminals. Display shows cooling icon, but no action from unit.
  • kramerbruce Jun 22, 2009
    Problem turned out to be a blown fuse in the furnace. No $ saved.
    Top Expert:
  • Honeywell Master
  • 81,424 Answers
The fuse blew fior a reason, this would be the thermal limiter fuse correct, make sure the condensor fan is not running slow, also make sure the condensor coils are clean. or the fuse will blow again.
Posted on Jun 23, 2009
  • 258 Answers
If the air conditioning is in use, a snowflake will appear, it seems like you are having trouble programming the thermostat or your aircon is shot
The customer care department can be accessed by calling 800-468-1502
also try their dedicated website for more information
www.Honeywell.com/yourhome
Posted on Jun 22, 2009
  • Brett McGuigan
    Brett McGuigan Jun 22, 2009
    It is a possibility that it hasn't been programmed for Cooling
    or it hasn't been wired for cooling to your air con only to your furnace for heating
    Try calling Honeywell Customer Care at 1-800-468-1502 ok
New instruction manual for RTH230B
Do you mean the Honeywell RTH230B programmable thermostat? Most of the Honeywell thermostat manuals are available here: http://yourhome.honeywell.com/en/faqs/thermostat . Scroll through the pages to find the RTH230B or use the search feature. The search engine found the installation and user guide in three different languages, see https://yourhome.honeywell.com/en/supportsearch#q=Rth230b . The direct link to the manual in English is https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-1800.pdf .
I hope this helps.
Dec 07, 2017 | Heating & Cooling
Furnace won't come on
10-17-12
Change battery on thermostat.
Usually located back of thermostat.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 16, 2012 | Hunter Fan Company 5/1/1 Programmable...
New thermostat..have heat but not A/C help....
What are you setting the thermostat to when you turn on the AC , if you turn on the AC and the house is warm you will need to turn the AC down to a lower setting before the the AC will start up.
Mar 14, 2010 | Honeywell Electronic Programmable...
My honewell th8320 is reading error 126 or 626
Look in the manual that came with the thermostat it will give you the problem for each code.
Nov 11, 2009 | Honeywell Electronic Programmable...
I just purchased a honewell RTH 221 thermostat. I
Typically the four thermostat wires are:
R = power (or common)
G= FAN
W = Heat
Y = Cool
Assuming that you have a normal electric or gas furnace and air conditioning, if the heat really is coming on, then just switch the position of the the Yellow and White wires.
Nov 02, 2009 | Honeywell Programmable Thermostat Heater
Honeywell RTH230B will not call for heat.
On a call for heat an internal switch should connect Rh and W, if it does not the stat is bad. Try it with no wires connected.
May 18, 2009 | Honeywell Focus 6300B 5-2 Days...
New honeywell thermostat on new gas furnace not working
sometimes there's a differential setting anywhere from 1-3 degrees, see if you can make sure it's down to 1
Nov 12, 2008 | Honeywell Programmable Thermostat Heater
Honeywell rth230b thermostat doesn't work
On most Honeywell Digital T-stats there is a 5 min delay built in
Oct 23, 2008 | Honeywell Programmable Thermostat Heater
Model RTH230B uses a lot of batteries
THIS TYPE has been deemed defective! changeout to a different type.
Sep 04, 2008 | Honeywell Programmable Thermostat Heater
Problem with Honeywell RTH230B Thermostat
Sounds like you have it wired wrong..   Pop the top off and give me to color of the wires and tell me which letter each color wire is on.. that will tell us right away if you have it wired wrong
May 27, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
146 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
