Question about Randell 20072SC R-134a Refrigerator
My Frigidaire r134a refrigerator is not cooling. The freezer part works great.
5 Suggested Answers
SOURCE: Refrigerator not cooling freezer working fine
Refrigerator suddenly not cold enough . Drip pan clean and dry. No dirt or dust.
Posted on Oct 06, 2008
Maytag317
  • 1136 Answers
SOURCE: Frigidaire AS-17 does not cool, freezer works fine
Hi, Check the freezer and see if the fan motor is running. Remove the rear panel and check for a frost or ice build up inside the rear freezer panel. Please let me know what you find so I can assist you further.
Vic
Posted on Jun 28, 2009
  • 239 Answers
SOURCE: Model R134a Refrigerator...Freezer works fine but
Two things, One, the coil in the freezer could be Iced up, deforst the freezer.
Two, the circulatng fan is not running.
Posted on Sep 03, 2009
  • 22 Answers
SOURCE: my Frigidaire refrigerator will not
u have a frozen drain in the freezer, thaw the fridge out manualy, for a day or so , then it will work fine for a short while sound like a defrost timer need replacing but make sure theres no ice in the freezer befor starting it up again
Posted on Oct 16, 2010
Frigidaire r134a the freezer is not cooling but the fridge is working
Bobby, I'm not sure what refrigerator you have but are you sure your refrigerator part is working? Did you actually measure the temperature in it? It should be around 40 deg F. The reason I ask this is because in most cases, the refrigerator portion of the unit receives its cold air from the freezer. This suggests that you can't have a problem in the freezer section without a problem in the refrigerator section. You may want to clarify this point before you move on with the diagnosis.
Dec 07, 2016 | Frigidaire Refrigerators
Where is the drain located on Frigidaire model r134a? is it the hole on the bottom freezer side?
R134A is not the model number. This is located inside the freezer on a white sticker on the left or right wall. Anyways, the drain is going to be located inside, behind the back wall of the freezer on the floor, directly below the Evaporator coils where all of the "cold" in your entire box is created. If you're referring to a refrigerator, there should be an aluminum tray/pan that all the defrost water drains down into. Sometimes they just freeze over & the hole becomes plugged w/ice. Hope this helps. Tips appreciated. Have a great weekend :)
Mr. All-Star
Jul 30, 2016 | Frigidaire Refrigerators
My Frigidaire refrigerator will not cool. The freezer is workin great.
Oct 16, 2010 | Frigidaire Refrigerators
Have not run in a year.Cleaned and put in garage.Freezer working great but bottom is not coolong and fan run all the time.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 31, 2010 | Frigidaire FRT17G4B Top Freezer...
Compressor not cooling r134a
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jul 18, 2010 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire 16.5cu top mount not cooling fridge. freezer is froze
The baffle that opens to allow cooling into the refrigerator may be blocked, broken or mis wired. These units work by just cooling the freezer and then blowing some cold air into the refrigerator whenever the fridge thermostat calls for it. The fridge's thermostat is trying to cool the refrigerator but something is preventing the cool air from getting to the refrigeration part, that's why it's freezing up the freezer
Mar 13, 2010 | Frigidaire FRT17B3A Top Freezer...
Frigidaire refrigerator does not seem to be cooling or freezing completely. Frigidaire refrigerator does not make any noise and does not seem to be cooling or freezing. I have checked the back of the unit...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
nmnm
Sep 24, 2009 | Frigidaire FRS3R5EMB Side by Side...
Model R134a Refrigerator...Freezer works fine but no cooling in the refrigerator... What can I do if anything besides replace it?
Sep 01, 2009 | Frigidaire Refrigerators
Oct 05, 2008 | Randell 20072SC R-134a Refrigerator
Randell 20072SC R-134a Refrigerator Logo
1,190 people viewed this question
Top Randell Refrigerators Experts
Marvin
Marvin
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Are you a Randell Refrigerator Expert? Answer questions, earn points and help others
