Question about Brother EM-530 Typewriter
How do i turn off the KBII
The KBII is on and i need to turn it off
How to type @
You are probably in KBII. Across the top row of keys there are letters one should be KBII Press alt with this key and you will go back to KBI.
DickyO
Jun 06, 2014 | Brother GX-6750 Typewriter
Code
You are probably in KBII Mode The code key with the top row key with KBII labled above it should get you out of that mode.
DickyO
May 09, 2013 | Brother GX-6750 Typewriter
How to type pound sign
You are most likely in KBII mode. There should be a slide switch or a top row key with KBII printed above it that requires the code key to turn it off.
DickyO
Jan 21, 2013 | Brother ML-100 Typewriter
Cant get the @ singh
You are in KBII mode. Code and the key in the top row with KBII above it will fix it.
DickyO
Oct 12, 2012 | Nakajima AE830 English Electronic...
Printing a lot of symbols
If it is printing the wrong symbol you are probably in KBII mode. There may be a KBII key or more likely a key in the top row with KBII above it, press code and that key.
DickyO
Jul 11, 2012 | Brother ML-500 Typewriter
I need to work with that simbol @ i dont know how?
You are most likely in KBII. There is a kry in the top row I bllieve it is the "5" key labeled KBII above it, code and that key will get you out of KBII and you will now get the @.
DickyO
Oct 12, 2011 | Swintec 7040 Typewriter
I am in the KBII mode how do I get out I try to type a 5 and get symbols
You didn't give a model but generally the KBII key is in the upper row and requires the use of the code key. If your problem is inly with the 5 key you may need a printwheel.
DickyO
Jul 29, 2011 | Swintec Office Equipment & Supplies
The & sign will not work the < always comes up how can I change this?
You are in KBII, usually code and a key with KBII ON IT.
DickyO
Jun 17, 2010 | Royal Satellite 80 Typewriter
How do I type degrees symbol on a Swintec 8014 S?
Tou have to go into KBII mode CODE and 4 or 5 KBII is marked above it then you can get to the Extra char. on the keys.
DickyO
Feb 09, 2010 | Swintec Office Equipment & Supplies
Brother EM-530 Typewriter Logo
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
