Question about Fluidmaster INC #B1F09 9" Faucet Connector
How to adjust water tank's buoy - Fluidmaster INC #B1F09 9" Faucet Connector
How do you adjust the clip so the water level increases?
You don't adjust the clip as it attaches to the pipe to automatic turn off the water at the right level, but your water may be set at to high a level that it overflows into the bowl. When that happens you can do 2 things to correct it: 1 at the wall where the cold water comes out to the toilet you can adjust it to slow the supply of water to a little less. 2. You can adjust the screw inside tank to tighten (turning screw one way) to adjust water level to shut off quicker or adjust tank screw the other way to fell take water up higher. Flush the toilet and observe the power of the flush. Allow the tank to fill until the water shuts off. Repeat the procedure to adjust the float and water level, if desired.
Apr 26, 2014 | Plumb Craft Waxman 7030700T Perfect Flush...
A65 unit does not indicate proper position. When alongside a buoy it shows the buoy ahead by about 50 feet. When the buoy is 50 ft behind the sail boat, the A65 shows it abeam. Even my handheld Garmin does...
You may be aware that the system is "detuned" for security reasons. With GPS, repeatability is the key. A bouy is NOT a stationary item, especially at low tide, I suggest that you test your accuracy with stationary objects. A map (chart) cannot know which way the tide is moving a bouy, only the approximate anchor location, the bouy floats and moves....
Mar 04, 2011 | Raymarine A65 GPS Receiver
Toilet continues to run because the buoy (the black plastic piece filled with air) gets stuck and does not rise up as tank fills with water. This is an intermittent problem. I tried adjusting the...
The buoy or float cup as it is known by may not be the problem. Try removing the fluidmaster top cap assembly and flush our the valve for debris. If the valve is several years old you may want to replace the top cap seal with model 242.
For more information call 1/800-631-2011 and speak to a Fluidmaster Tech
Aug 17, 2010 | Fluidmaster INC #B1F09 9" Faucet Connector
Water continues to overfill in tank into refill valve
Hi and thank you for using fixya:
Inside the tank there is a long standing tube that at the top end it has a little buoy that regulates how much water needs to be in the tank if you push it up you are going to see the water stops to run. So just bend it down a little about an inch
thanks
May 04, 2010 | Kohler - Toilet - One-piece - Santa Rosa -...
How do I adjust tank fill valve to increase water level in toilet?
There are many different fill valves out there so it would be a little hard to tell you how to adjust your particular one without knowing the brand and type of the fill valve.
So I will give you a generic adjustment.
Look for someway/something to adjust your float in the toilet tank.
There should be a screw, moveable metal, something that will adjust your float.
Once you locate the adjustment, you can then adjust your water level in the toilet tank.
Adjust the water level in the toilet tank to be about a 1/4-1/2 inch before it flows out of the overflow tube when the water shuts off.
Good Luck, I hope this helped.
Please rate me, Thanks
Mar 11, 2010 | Home
The bowl does not clear when flushed. I wonder if the volume of water needs to be increased. But I don't know how to adjust it.
Hi
It depend on type of mechnisim you got in the water container .
look for some kind of screw that sets the hight of the buoy. paly abit with that screw to see which way to turn it .
good luck
Jul 16, 2009 | Home
I need a new bulb for my glow buoy pool light! how much and were thanks!!!
The Glow Buoy swimming pool lights were designed so that the bulbs can only be replaced by a licensed pool supply store. If you open the light yourself, you will void any warrantly and risk breaking the unit. Becuase of this, they don't sell the exact bulbs that you need unless a pro is installing them.
Jul 07, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
Overlapping maps on a C330
On Page 17 of your manual:
Go to Tools > Map > Map Info
This should show you the mapping software installed on your unit. Uncheck the one you don't want to use.
Apr 02, 2008 | Garmin StreetPilot C330 GPS Receiver
Fluidmaster INC #B1F09 9" Faucet Connector Logo
77 people viewed this question
Top Fluidmaster Plumbing Experts
Jim Goldsmith
Jim Goldsmith
Mack Baxter
Andrew Bugbee
Are you a Fluidmaster Plumbing Expert? Answer questions, earn points and help others
