Question about KitchenAid KESA907PSS Electric Kitchen Range
How to replace oven door on Kitchen Aid ykerc507hw4 without jamming?
3 Suggested Answers
fixyourboard
  • 310 Answers
SOURCE: Kitchen Aid KESC307 Electric Range oven shuts down unexpectedly
We've seen similar problems due to an intermittent failure in the control board. If you can have it removed we can likely repair it for you.
Best Regards,
Bruce
www.fixyourboard.com
Posted on Oct 13, 2009
Testimonial: "Prompt response and likely the solution although I have not experienced the problem again. "
pappapumpdaf
  • 635 Answers
SOURCE: Kitchen-Aid Electric control panel buttons stopped working
This may sound facetious, so don't get offended.
Did you set your clock to the correct time?
Did you clear any and all preset timers?
If none of that helps you can usually find roaches in the strangest places. If you have no roaches, then moisture and heat are the likely culprits which means that your blister pads are simply worn out. Unfortunately these are coated with graphite and don't last forever, so a timer replacement would be your only option unless your touchpad is separate from your timer.
Posted on Mar 05, 2010
Needd to change kitchen aid wall oven from celsius to fahrenheit
Press and hold the Broil Max Econo button for 5 seconds.
Only this button and without turning on oven.
Feb 17, 2013 | KitchenAid Kitchen Aid KEBS177SBL Single...
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
Mar 05, 2010 | KitchenAid KERC507 Electric Kitchen Range
I have a Kitchen Aid range model KGST307GBS0. The
The door light switch was broken (upper right face of oven). The door switch is automatically activated when the door is opened to turn on the oven light. When the door is closed the switch is depressed to turn off the light. It seems the switch position is detected by the oven and if it is in the open position it will not allow the oven to function properly (reach temperature or allow the cleaning cycle to run). I temporarily locked the broken switch in the closed position, which allows the oven to function. A new switch was ordered for replacement.
Jan 02, 2010 | KitchenAid KGST307 Gas Kitchen Range
Kitchen Aid microwave door -- outer glass
Lisa, I do not have a solution, but have the same problem. My KA superba micro has been used about 10 times. While it was off, and while no one was home, the outer glass in the door shattered. I suspect this may be a defect.
Jun 19, 2009 | KitchenAid Architect Series KEMC308KSS...
Finding replacement part # 4164235 for inner door glass
I am looking for a Kitchen Aid part # 4164235, a Window Pack for the inner door of my Kitchen Aid Oven door.
May 16, 2009 | Whirlpool RBS305PDS Electric Single Oven
KitchenAid KESA907PSS Electric Kitchen Range Logo
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
