Question about Metabo Saws
I removed the head assembly and cannot get it to go back in
  • 2,176 Answers
What brand and model number. Did you move the brushes out of the way so you can reinsert the armature, also some of them used a rubber cup on the bearing that has to be installed swuarely. Let me know and I will find you a breakdown for this tool.
Posted on Aug 10, 2009
How do you remove front head light cover in order to replace headlight?
the head light bulb is on the back side
there is two locking pins under hood holding the assembly in
rotate 1/4 turn and pull up pull assembly put and unplug
remove retainer ring and remove bulb
assemble in reverse test new bulb before mounting light assembly back in
Jul 15, 2011 | 2003 Chevrolet TrailBlazer
I'm having a problem removing the headlight assembly from my 2004 chrysler crossfire, i've removed the 2 screws from the top and removed 1 from below through the wheel well, are there two screws...
Last I checked Chrysler had changed it's headlight mounting from external screws to just the two adjusting screws. Looking down from the top, you should be able to see two Torx head screws that are used to adjust the headlight assembly. The remove teh head light assembly you remove those and the assembly should come right out. Both of these screws or adjusters will be 6 to 8 inches long. I hope your not removing this to change the headlight it self. Chrysler has been using the insert bulbs for several generations and to replace the bulb you only have to unlock the collar on the back of the light assembly and pull and then replace the bulb.
May 14, 2011 | 2004 Chrysler Crossfire
Wrong cartridge error. you cant do anything with it nothing works
Fix for Canon ImageCLASS MPC600:
- Remove Cartridge/Head assembly.
- Press 'On/Off' to shutdown (choose language, 'OK').
- Press 'On/Off' to switch back on.
- Re-insert Cartridge/Head assembly.
- Run through head alignment.
- Smile!
Apr 17, 2011 | Canon MultiPASS MP700 All-In-One InkJet...
HOW TO REPLACE HALL SENSOR ON LG TROMM
Unplug machine. Remove back panel (4 phillips head screws). Remove large bolt in center of motor. Pull motor rotor off shaft. Remove phillips head screw(s) holding wire protector and possibly ground wire at bottom of motor area. Remove metric bolts from motor coils and remove coil assemble. Unplug 4 wire harness from Hall sensor. Unclip Hall sensor from coil assembly. Install new Hall sensor, and re-assemble. Plug machine back in. There. Done, and it only took 10 minutes!
Mar 27, 2011 | LG WM1814CW Front Load Washer
Removal of head light assy 1989 ford ranger.
To remove the front head light please follow the steps below:
  1. Place the Ford Ranger in "Park." Turn the engine off. Turn the headlights off. Remove the key from the ignition. Allow the truck to cool for about 20 minutes.
  2. Open the hood of the vehicle. Locate the two retainer pins on the headlight assembly of the light that needs to be replaced. Pry the retainer pins open with your finger. This releases the headlight assembly from the Ranger.
  3. Pull the headlight assembly forward. Unplug the electrical connector from the back of the assembly by hand. Rotate the retaining ring counterclockwise and slide it off the plastic bulb base.
  4. Pull the burned out bulb straight out of the headlight assembly. Discard the used bulb. Insert a replacement bulb into the headlight assembly and push it straight into the socket until it clicks into place. Slide the retaining ring around the bulb and rotate it clockwise to secure it.
  5. Plug the electrical connector into the back of the unit. Slide the headlight assembly back into the Ranger. Push the retaining pins back down to secure the headlight assembly.
Hope this helped. thank You for using FixYa!!!
Jan 19, 2011 | 1989 Ford Ranger
Pajero io 1.8 water leak at the back of the cylinder head, guide me ho to fix!
Cylinder Head Removal & Installation To Remove:
  1. Remove the intake manifold.
  2. Remove the timing belt.
  3. Disconnect the exhaust pipe from the manifold.
  4. Remove the water outlet pipe and o-rings.
  5. Remove the water passage assembly.
  6. Remove the water pipe assembly.
  7. Remove the breather hose and spark plug cables from the rocker covers.
  8. Remove the rocker cover.
  9. Disconnect the camshaft position sensor connector.
  10. Loosen the cylinder head mounting bolts in 3 steps, using the reverse of the installation sequence. Lift the cylinder head assembly and remove the head gasket.
To Install:
  1. Clean the engine and cylinder head sealing surfaces.
  2. Install the new gasket on the engine with the identification mark facing up and to the front.
  3. Using 3 even steps, torque the head bolts in sequence, to 76-83 ft-lbs. (105-115 Nm). Cylinder head bolt tightening sequence 7924ug13l.gif
  4. Connect the camshaft position sensor connector.
  5. Install the rocker cover.
  6. Install the breather hose and spark plug cables from the rocker covers.
  7. Install the water pipe assembly.
  8. Install the water passage assembly.
  9. Install the water outlet pipe and o-rings.
  10. Disconnect the exhaust pipe from the manifold.
  11. Install the timing belt.
  12. Install the intake manifold.
Oct 19, 2010 | 2001 Mitsubishi Montero
Can't get to passenger side head light to change it
Directly behind the head lamp assembly there are 2 tabs.These hold the head lamp assembly in place in back.Pull up on both of these and the complete assembly should pull out.Then remove the covers and replace the bulb that needs replacing.Check and make sure it works before you put it back together.Good luck.
Nov 19, 2009 | 2006 Buick LaCrosse
Remove head light assembly
when you open the hood you will see a plastic part on top of the bumper you will have to take that off with some needle nose pliers...then on the head light you will see some metal things that could open if you pop it up..with the same pliers pop up the metal on both sides and the head light will come off...when installing back you will have to push it back down
Mar 22, 2009 | 2001 Pontiac Grand Am SE
2005 Dodge 1500 code p0404 EGR valve.
The electronic EGR valve and solenoid assembly is attached to the rear of the left cylinder head ,
  1. Remove electrical connector (5) at top of EGR valve solenoid.
  2. Remove tube mounting bolt (1) at intake manifold.
  1. Remove two bolts (4) connecting EGR tube (1) to valve assembly.
  2. Remove gasket located between EGR tube flange and EGR valve assembly.
  3. Remove two EGR valve mounting bolts (5).
  4. Separate valve assembly (3) from engine.
  5. Remove and discard metal gasket located between cylinder head and valve assembly.
INSTALLATION
  1. Clean area at rear of left cylinder head where it joins base of EGR valve.
  2. Clean EGR tube where it joins EGR valve.
  3. Position new gasket between EGR valve and cylinder head.
  4. Position EGR valve to cylinder head. Install and tighten two bolts (5). Refer to Torque Specifications.
  5. Position new gasket between EGR tube flange and EGR valve assembly.
  6. Position EGR tube (1) to side of EGR valve and into intake manifold.
    1. Install EGR tube flange bolt (1) at intake manifold. Tighten bolt. Refer to Torque Specifications.
    2. Connect electrical connector (5) to top of EGR valve solenoid (2).Do a final tightening of two EGR tube bolts (4). Refer to Torque Specifications
Feb 05, 2009 | 2005 Dodge Ram 1500
Removing Headlight Assembly on 2003 Ford Focus Ultimate Edition
Jack up the front of the vehicle. Secure the vehicle with at least once JACK STAND. Open the hood of the car. Remove the front grill. Remove the fasteners on the head light assembly that are located on the exposed inner fender and the one that was under the front grill. Lay on your back and look between the front fender and the head light assembly. You only have about 4 inches. Remove that screw. All screws are either Phillips or torks.
Dec 24, 2008 | 2003 Ford Focus
Saws Logo
103 people viewed this question
Top Metabo Saws Experts
Vernon Taylor
Spud Howell
JOHN LAPIER
Are you a Metabo Saw Expert? Answer questions, earn points and help others
