Question about Harbinger APS 15 Powered PA Speaker
Harbinger APS 15 Powered speaker fuse - Harbinger APS 15 Powered PA Speaker
Harbinger ha120 no sound to speakers. What's wrong?
It could be a number of things. Does the head light up when turned on? Are the controls on the channel turned up? Is the master turned up? Have you checked continuity on the cables? Have you tried the speakers with another amp, or the amp with other speakers? This will help narrow down the problem.
Sep 21, 2015 | Harbinger Music
Powers on but no sound
This is most likely a power supply issue which will require a trip to the repair shop.
Aug 27, 2015 | Harbinger APS12 12 Powered PA Speaker
Why does my harbinger aps15 speaker keep blowing fuses when powered up.
probably shorted the integrated amp chip...they are not worth the trouble to fix..buy some good equipment.
Sep 20, 2014 | Harbinger APS 15 Powered PA Speaker
Crossover schematics
measure it with a fluke or similar multi-meter
Jul 16, 2014 | Harbinger APS12 12 Powered PA Speaker
Speaker shorted out
If you do not have training in electronics you can cause serious damage to yourself trying to fix this. You will need to take this into the shop.
Jan 17, 2014 | Harbinger Music
Harbinger APS 15 has a broken horn
Where can I buy a horn for my speaker?
Jun 19, 2012 | Harbinger APS 15 Powered PA Speaker
Peavey Pr-15 fuse blown, speaker not working. What is the fuse rating
Actually its pretty funny thing with those speakers is the "fuse" is Actually called a Lamp in this case. These are what they call a " Red Dot Fuse ". in all the years i've been doing this i've never thought to look up the value haha. Just have to know there are Red Dot lamps and Blue dots and No Dot. If you examine the LAMP you should see somewhere close to the ends ON THE GLASS a color dot of some kind. almost like someone painted it on there. Red Dot Lamp. any parts distributer for people like Harbinger, Peavey, and B52 will KNOW what your talking about
Aug 21, 2011 | Peavey PR15 400w PA Speakers
Just bought a Harbinger HX121M 2" Monitor, from Musicians Friend it did not come with a booklet on how to wire into my sound system it has two 1/4" jacks and a strange round plug about the size...
If you don't know how to connect this... well we don't either because you did not tell us what your sound system is. The larger plug is what is known as a "Speakon" connector and is a fairly reliable speaker connection that is used now. For your use you will PROBABLY use either of the 1/4 inch jacks with a cable from the amp that will drive the monitor(s). If you have multiple monitors you will daisy chain them using the 1/4 inch jacks and SPEAKER rated cables creating a string of speakers with input going into one and an output from the same one to the next speaker and so on...USUALLY you will be limited to two speakers per amp output...
Aug 15, 2011 | Harbinger HX121M 12" Stage Monitor
Harbinger APS 15 Powered PA Speaker Logo
57 people viewed this question
Top Harbinger Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Harbinger Music Expert? Answer questions, earn points and help others
