Question about Williams-Sonoma Vitamix Professional Series 750 Blender | Williams-Sonoma
Smoothie setting does not work??
Ingredients are put in and it starts but stops very quickly and will not continue
Recepies for the cactus smoothie
Some of the names of cactus smoothies are:
a. Detox Cactus Smoothie
b. Pineapple Cactus Smoothie
c. Cactus Pear Green Smoothie
d. Nopal Cactus Smoothie, etc
Nov 29, 2016 | Blenders
My Smoothie Maker just stopped working...the motor will not turn on at all. What do I do?
Hi Lou:
I'm assuming the power did not go off.
If you have access to a continuity meter?????
Unplug it. Connect meter to plug prongs. Turn switch on.
If no continuity, start checking for broken wire, faulty switch, whatever it takes to isolate the place where continuity is, and is not at. The problem is between those two places.
Cheerfuls.
Sep 08, 2015 | Blenders
Best blender brand for smoothies and juicing?
I would recommend to invest in a high quality blender that can perform all blending operations. If you're going to blending a bunch and need high speed blender to prepare smoothies and juices quickly. Vitamix will be a great option.
GroomNStyle Best Kitchen Blender Reviews 2015
Jul 29, 2015 | Blenders
What are the best ways to use a Ninja blender?
It can perform almost all task of your kitchen, can make nice smoothies, prepare chunky ingredients and much more. It can crush ice fast. Would be a great choice for kitchen use, quickly prepare everything you want. It is also affordable and has stylish design.
Check out GroomNStyle.com for more information.
Jul 28, 2015 | Euro-Pro Ninja NJ600 Pro Blender - NJ600
Smoothie pro 600 manual
It means it's working very hard,
I suggest to put items that are thick in first and blend them then add the other ingredients after , the smell is the coating on the motor getting hot , if you see smoke coming out, drink your smoothie wash it out and take it back for a new one.
Jan 06, 2014 | Blenders
Blender stopped working
Sounds like the motor burned out.
Jan 30, 2012 | Black & Decker Blenders
I have a Vita Mix 3600. I was making a fruit smoothie (banana, blueberry, raspberry), milk, small scoop of protein powder . Speed was on 1. I depressed the lever to reverse. I don't remember if I had...
Yes that is strange, if you let it cool down and try it again with pushing the re-set button and still does not work, try plugging it into a different outlet. Find something in your place that you know outlet is working, lamp, toaster you know. If does work in another out let, then you of course griped that breaker. Then check your breaker box to see what breaker is tripped, and switch it back on, might just of had a power surge based on putting on reverse. If that don't work, I suppose possibly something in motor or switch went out. Please let me know, if it works, I will take a banana smoothie LOL
Jun 09, 2011 | Vitamix Vita-Mix 1364 3-Speed Blender
Cuisinart Quick Prep is not working properly
I think the ice was too hard for a hand blender. I think the impact has caused the blade to separate from the shaft or caused the shaft to separate internally. If your blender is still under warranty you might be able to get it fixed. Note: none of the "Smoothy" recipes in the manual call for ice. One uses ice-cream. One uses "partially thawed frozen strawberries" and one uses sherbet.
Oct 11, 2009 | Cuisinart CSB-33 Quick Prep Handheld...
Back to basics auto serve smoothie machine
Ok here is a number for you too call Tell them your problem and they should have no problem sending you the part you need being that it is new!.....866-290-1851. they are available by phone Monday through Thursday 7:30am until 5pm and Friday 8:30am until 4pm C.S.T. You may need the make and model number (should be on unit!) I think they are a division of west bend inc.
Please rate my response!
Thank YOU!
Jan 15, 2009 | Back to Basics 600 Smoothie Plus Work Top...
Williams-Sonoma Vitamix Professional Series 750 Blender | Williams-Sonoma Logo
27 people viewed this question
Top Williams-Sonoma Blenders Experts
eyecam
Are you a Williams-Sonoma Blender Expert? Answer questions, earn points and help others
