Question about Konica Minolta Office Equipment & Supplies
Adjust binding margin - Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,161 Answers
What model ####
Posted on Dec 29, 2015
How do I make the margin wider to where the comb binding holes punch
Adjust your text in your word processor,. WORD?
Look up File - Page Setup - Margins
Oct 02, 2015 | Office Equipment & Supplies
Margin bypass is in down position when typewriter is off and carriage return key will not work
Check you shroud or keyboard cover, if they get bumped it can bind the MR key (margin release). Re-align cover plate for proper clearance.
Jan 18, 2014 | Smith Corona Office Equipment & Supplies
Typewriter carriage
The typewriter needs the escapement adjusted, or you have a bind in the escapement, and it probably needs a good cleaning and oiling. This usually done by a pro.
Oct 07, 2013 | Office Equipment & Supplies
Toshiba e233 photocopier does not coincide with the top margin of the original copy
Top margin??? SEF or LEF
1. If it is the lead edge registration, go to 05 mode and adjust the values of the following...
440 > start > adjust value (for upper drawer margin)
441 > start > adjust value (for lower drawer margin)
442 > start > adjust value (for bypass drawer margin)
443 > start > adjust value (for LCF)
2. If it is the side registration, adjust it from the drawers.
Nov 30, 2012 | Office Equipment & Supplies
I have a panasonic electric typewriter R330 and it only types about in inch then stops how can i fix it?
The right margin is probably set. Hit margin release( MR) and see if it types, if so reset your right margin. Also something could me binding or caught in the path. maybe a correction ribbon or something is blocking it.
May 30, 2012 | Panasonic Refurbished Kx-r330 Typewriter...
I am trying to print a booklet 2 pages per sheet double sided. Printing is OK but spacing is no good for the binding when the pages are cut in two. What instructions should I give the printer to allow...
Hi
By spacing, I assume you mean the margins at the centre.
The default margin settings are not the same for the right and left hand side of the page, so the printing on the reverse side is offset from the printing on the first side.
The right margin is always wider to allow for punch holes in file paper.
It is not the printer settings you need to adjust, it is the page layout of your word processing software.
Adjust the margin settings manually. In MS Office 2007:
Page Layout > Margins > Mirrored Margins.
Hope this helps.
Aug 24, 2011 | Canon PIXMA MP610 InkJet Printer
My typewriter keeps binding up and will not go far enough across
Most likely, the problem is not with the margins. The most common fault (loosing margins) is caused by the carrier binding on the shaft that it travels on. Solution:
Turn off the power
Locate the shaft that the carrier travels on (usually about 1/2 to 3/4 in. diameter, chrome shaft in the middle or lower/rear of the open area that the printer travels back-and-forth in).
Apply a few drops of 10 weight oil acroos the shaft and wipe with a cloth. Move the carrier manually to the right side of machine and repeat the prosess on the left side of shaft. Lubricate some more and repeat the process. NOTE: 3 in 1 oil is OK. . WD 40 IS NOT
Nov 11, 2009 | Smith Corona Office Equipment & Supplies
Need to reset all the margins on IBM Wheelwriter 10 Series II. The margin release button will not release the left margin.
The problem may be that the carrier is binding on return, put some light lube (WD40 works well) on the silver shaft that the carrier slides on.
DicktO
Jan 15, 2009 | Lexmark Wheelwriter 6 Series II Typewriter
Paper margin problem in pagemaker application
Do you mean the left margin is too large so all the content is shifted to the right and off the page? If this is the case, it is probably a setting in Pagemaker. In the file menu, choose "page setup" or "print setup". Check the paper size. Check the margins.
Jun 24, 2006 | HP Color LaserJet 2600n Printer
18 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
