Question about JVC TH-A25 System
How to clean lens on sony dav-dz150k - JVC TH-A25 System
My Sony dav-dz150k home theater is displaying push power protect.I checked the the sound output,the speaker wires for shorting but are fine
Hi.please check on your device control panel if you have power control key push it ,if not please see behind the device it may be there
May 22, 2016 | Sony Audio Players & Recorders
Display shows "push power protection"-DVD home theater system
there is a short in the amp that needs to be repaired before the unit will operate correctly.
Feb 12, 2013 | Sony DAV DZ150K DVD Home Theatre Music...
I have a Sony DAV-FC8 that I purchased in 2003. It is starting to have more and more difficulty reading DVD's, as well as encountering problems during playback. I am fairly sure this is a result of...
First of all its not as easy as you think to clean the optical lens in some of the Sony systems because they have put a dust cover over the whole DVD mechanism ( unlike older systems where you could access the lens just by removing the top metal cover ).
You will have to remove the top metal cover , then remove the plastic dust cover . Using a cotton ear bud gently clean the lens ( looks like a fish eye ). Put everything back in the reverse order and try. If it still does not work you will have to replace the whole unit itself.
Mar 17, 2011 | Sony DAV-FC8 System
My Sony DAV-DZ720 Theater System not read the some dvd disc,.,i think problem is in lens system,..help me to fix lens pls,tanx
First try playing a CD. If that too skips you can clean the lens by opening it.Dust on the lens will effect all types of disc and will not be selective.
You can buy a lens cleaning disk from any Cd store and play it to clean.
The cleaning action takes place only if the disc rotates, so keep the top lid off to see if it rotates.
If you have crossed 500 hours of playing may be the lens is due for a change.
Mar 08, 2011 | Sony DAV-DZ720 Theater System
Hi!! I have a SONY DVD player(model- DAV DZ150K)...Recently it has refused to play DVDs (it says "cannot play this disc") and only plays VCDs and ACDs...please help!!!!
I have 1 sony DVD Model No-DAV-DZ150k .When i have select DVD mode so dest error show on VFD Disply .Pls tell me what is problem in DVD.
Oct 15, 2010 | Sony DAV-DX255 System
Can i use a lenscleaner for sony dav-s880?
Yes, put lens cleaner disc in home theater and press play to clean lens.
Jul 08, 2010 | Sony DAV-S880 System
I HAVE Sony DAV-S880 Theater System THEY DINT READ ANY DVD.
What city of Pakistan do you live Mr. Saqib Khan to help you out.
Thanks.
Jun 18, 2009 | Sony DAV-S880 System
DAV-S880 doesn't accept audioCD
does it say's no disk ,then try some diffrent audio disc,or put small amt of tape on bottom side of disc in the inner hole and try.
Dec 25, 2008 | Sony DAV-S880 System
JVC TH-A25 System Logo
20 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
