Question about Avaya 4406D Phone
What does OG mean?
OG is in the upper right hand of the phone screen. What does OG stand for?
How do I delete list of "New Calls"
If you've got an iPhone, you probably already know that it can provide you with a history of your calls. You can also edit your call history if and when you need to by deleting individual call records. Whatever the reason (hey, we don't judge), we can walk you through how to delete certain phone records out of your call history.
  1. Launch the Phone app from the Home screen of your iPhone.
  2. Tap on the Recents tab along the bottom of the screen.
  3. Now tap on the Edit option in the upper right hand corner.
  4. You'll now see that each phone record now has a delete option to the left of the caller's name or number. Tap on it.
  5. To confirm the delete, tap on the Delete button off to the right.
  6. Repeat this process for the calls you'd like to remove and once you're done, tap on the Done option in the upper right hand corner of the screen.
That's it, those calls will now not appear in your recent calls any longer.
How to delete individual call records from Recent Calls on your iPhone
Nov 15, 2016 | Cell Phones
How can I check my purchases so that I can find my voucher?
Hi Anne
On a computer: Select "my vouchers" in the upper right-hand corner of the page.
On a mobile phone: Select 'vouchers' at the top right-hand corner of the screen.
In the iOS app: Select 'vouchers' at the bottom right-hand corner of the screen.
In the Android app: Select the menu button in the upper left-hand corner of the screen and select 'my vouchers'.
From the "my vouchers" page of your account, you can also sort your vouchers by expiration date -- this is a convenient way to see which ones you need to use soon or mark a voucher as "used" to remind yourself that you've already enjoyed it!
May 01, 2016 | Cell Phones
How to delete email trash from iPhone 4s?
Which iOS are you using? If you are using the most current iOS, from the email screen where you can see your emails, click Edit in the upper right hand corner and then select the messages you want to delete. Then click Trash in the lower right hand corner. Should work.
Jul 20, 2014 | Apple iPhone 4S
Need radio cd wiring diagram for 2005 jeep grand chrokee
120706502.jpg FUNCTION PIN WIRE COLOR Accessory 12 Volt SEE NOTE ¹ Constant 12 Volt 1,12 RD/OG (2X) Chassis Ground 11,22 BK (2X) Power Antenna Remote Illumination Dimmer FUSE VALUE FUSE LABEL FUSEBOX LOCATION 20 AMP #28 DRIVER'S SIDE UNDER HOOD ¹ The receiver does not have an Accessory 12 Volt lead, it is triggered by the data lines in pins #5 and #6. When installing an aftermarket stereo, an Accessory 12 Volt lead must be run to the fusebox to a switched power lead.
² If equipped with "Hands-Free" cellular phone system.
The dash speakers are wired in parallel with the front door speakers.
Left Front Spkr + 10 D.GN Left Front Spkr - 9 D.GN/BN Right Front Spkr + 7 GY Right Front Spkr - 8 GY/BN Left Rear Spkr + 18 D.GN/D.BU Left Rear Spkr - 19 D.GN/VT Right Rear Spkr + 21 GY/D.BU Right Rear Spkr - 20 GY/TN Hands-Free Audio ² 4
16
17 D.GN/OG
D.GN/YW
D.GN Data Lines 5
6 WT/OG ¹
WT ¹ DO NOT USE THESE WIRES!
Sep 25, 2011 | Car Audio & Video
The LCD og my phone sony ericson w550i turning to white
When it shows white, can you recieve or make calls? If you can recieve or make calls, that means the fault is from the screen but if you cannot recieve or make call, it means its a software problem (virus).
For screen fault, the screen needs to be replaced.
But for software problem, you need to take the phone to a technician. The technician will use computer to flash the phone for you.
Take care
Dec 16, 2009 | Sony Ericsson W550i Cellular Phone
What does the flashing red hand in the upper right
The flashing red light is warning you that the shutter speed will be too long for handholding the camera. Put the camera on a tripod or other stable surface, and/or use the flash.
Nov 08, 2009 | Nikon COOLPIX S9 Digital Camera
Remove images onto microSD
You can change display of your phone & fix this problem Permanetly.
Remove memry card from phone, Connect it to another phone & copy your photos to your PC.
Thanks.
Sep 22, 2009 | Nokia 6133 Cellular Phone
LCD Screen says ''2 missed calls''
The "[1]" (or other number) in the upper right is the number of the extension. If you have more than one extension, they will each have their own number. Unfortunately, I can't anwer your other question as I have the same problem myself.
Feb 16, 2009 | Panasonic KX-TGA101S Cordless Handset
Picture of a hand w/a F on bottom of screen
Hand icon is there because Manual Focus is activated.
Set camcorder to auto-focus and hand sign will disappear.
Dec 26, 2008 | Sony Handycam DCR-DVD201 DVD Camcorder
Avaya 4406D Phone Logo
154 people viewed this question
Top Avaya Lands Phones Experts
Oloyede Monsuru
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
