Question about Koolatron Mini Fridge Compact Refrigerator
Koolatron Mini Fridge Overheating
I have a Koolatron C18 Mini Fridge, which is 3 months old. Up until two days ago, it was working fine, staying at it's lowest possible temperature, 4 degrees celsius. But then, the temperature started to go up like crazy, and the top of the fridge would get insanely hot. What can I do to fix this?
  • snemec Dec 30, 2007
    i have a koolatron rack-n-roll pc50e. we just received this as a gift and first time using it. we plugged it in, set the temp to 39, second control at 74. we can hear the fan and the outside of the damn thing is warm but inside is not cool at all. any suggestions would really help
  • Anonymous Mar 14, 2014
    The temp display used to be in Celsius, but we recently had problems with the fridge and it's now in Farenheit. How do we change it back?
    Scholar:
  • 146 Answers
Check the condensor fan behind the fridge which is designed to cool the compressor/gas line by blowing air over the condensor. When this fan motor seizes or stops running, the gas gets very hot and because it is skin cooled too, the outside of the fridge also gets very hot. You can overcome the problem temporarily by putting a standing fan behind the fridge, blowing onto the compressor and under the fridge untill you can have the problem rectified.
Posted on Nov 04, 2007
Galaxy mini fridge stopped working
The thermostat, which is also an ON_OFF switch has failed (@ 99% probability).
No, the little fridge doesn't have a pressure switch to turn the compressor off when freon is low. And no, auto freon is the wrong kind and it wont work in the little fridge. The freon that your little fridge uses is the stuff that all the fuss has been about (with the ozone layer), so it is not sold to appliance owners but only to licensed techs.
If this is helpful I hope you'll take a sec to rate me. Thanks!
Don
Mar 24, 2012 | Koolatron Mini Fridge Compact Refrigerator
My acer laptop is about 6 months old and was working great till few weeks ago , i had to format few days ago because it was lagging overheating missing files discont me on line every 2 mintues , wouldnt...
If your internet is not working properly then reset your router and configure again.
Scan your computer with updated antivirus.
Also check RAM memory is works fine.
If it over heat then put extran fan so it control heat.
let me know if you need further assistance.
Thanks.
Oct 30, 2009 | Toshiba Portege 7100 Notebook
Whirlpool Gold refrigerator is not making ice. Just stopped 3 days ago for no apparent reason. Fridge is 6 months old.
as long as the fridge is working properly the only thing that it could be would be the icemaker...the fridge should still be under factory warranty if it's 6 months old so they should cover it
Oct 03, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Frigidaire plht189sska top freezer fridge problem. Freezer is cold, fridge is warm. About a month ago, had the problem of frost build up in freezer, water pooling under veggie bins, warm fridge. ...
If the defrost heating element, defrost timer or evaporater fan weren't working, you'd develop a block of ice on the evaporator. Is the compressor running? If it is, it might have bad valves from the frost buildup scenario. Liquid refrigerant could have gotten to the suction valves. The sealed system should have a five year warranty. Might be time to call a pro
Sep 15, 2009 | Frigidaire PLHT189CSB Stainless Steel Top...
Fridge not staying cold, periodically
CHECK FAN OPERATION   MOST OF THE TIME IT IS THE THERMOSTAT
Aug 12, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator will not get cold, but freezer works
Make sure your fan is working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked (usually with ice).With out a fan you have no circulation but your freezer may look likes its working,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open untill all traces of ice are gone this will free up any clogged tubes. Good luck.
Len West
Feb 27, 2009 | Amana ABB1927DE Bottom Freezer...
JCD2295HES side by side not working correctly
yes that does sound like a bad evap fan motor then unable to circulate air aorund and off hte evap thus building up frost.you can pull the wire leads of the fan motor and ck for 110v. to confirm that you are indeed getting power to the motor.
Mar 05, 2008 | Jenn-Air JCD2295HES Side by Side...
Top Freezer and Fridge not working
WHEN ITS NOT WORKING DO YOU HEAR A CLICKING OR BUZZING SOUND (IF SO BAD COMPRESSOR OR OVERHEATING)SEE BELOW
ALSO CHECK THE CONDENSOR FAN IN BACK IS IT RUNNING WHEN THE COMPRESSOR IS RUNNING
Feb 18, 2008 | Frigidaire FRT8IB5EW 30" 18.2 Cu. Ft. Top...
Koolatron Mini Fridge Compact Refrigerator Logo
1,367 people viewed this question
Top Koolatron Refrigerators Experts
Ilia Bichin
richie46
Your Consultant
Are you a Koolatron Refrigerator Expert? Answer questions, earn points and help others
