Question about LG Flatron L1951S 19" LCD Flat Panel Monitor
Where is the menu button on LG monitors - LG Flatron L1951S 19" LCD Flat Panel Monitor
How do I unlock screen controls for LG W53 27" monitor?
Press and hold the Menu button for several seconds to toggle the OSD (on-screen display) Lock on and off. The Menu button is the third button from the left in the group as you look at the front of the monitor. You should see a message on the screen when the OSD lock is disabled.
The OSD Lock feature is described in the manual and is the same for all W53 monitors. See http://www.lg.com/us/support-product/lg-W2753VC-PF for the manual of one of the monitors. The direct link to the manual came up as http://www.lg.com/us/lgecs.downloadFile.ldwf?DOC_ID=KROWM000230850&what=MANUAL&fromSystem=LG.COM&fileId=KROWM000230850.pdf&ORIGINAL_NAME_b1_a1=W2753VC_EN.pdf .
I hope this helps.
Apr 12, 2016 | LG Computers & Internet
Best way to remove a parental lock from a lg plasma tv
LG Service Menu Instructions
Method 1
Press and Hold <OK> button on remote as well as TV panel at the same time for a few seconds.
Method 2
Press and hold the {MENU} button on the remote and the {MENU} button on the TV at the same time for at least 5-7 seconds.
Method 3
Press and hold the {MENU} button ON THE REMOTE until a 4-digit password screen is displayed.
LG Service Menu PIN/Password Codes
  • 8 7 4 1
  • 8 7 4 3
  • 7 7 7 7
  • 0 0 0 0
  • 8 8 7 8
  • 0 4 1 3
LG LCD Monitor Service Menu Instructions
  1. First turn off the lcd monitor, then press and hold the "MENU" button, then turn on the monitor. Release MENU button after the monitor is turn on.
  2. Press "MENU" button to open the OSD menu, at the bottom of menu, you can see a new selection to go into the factory service mode. Inside the factory service mode, you can see useful information like, product model, manufacturer date, F-ENGINE chipset version, lcd panel number and etc.
Mar 16, 2016 | LG Televison & Video
How do I adjust the brightness on LG W2053tp
Look for the buttons, enter menu and the Brightness setting then use + or > to go up
Mar 07, 2011 | LG Flatron F700P 17" CRT Monitor
What is combination for entering service menu on LG M1962D?
1. Power off your monitor with POWER button
- Hold MENU button and keep it pressed while pressing POWER button
2. Press MENU button to enter Service menu
3. Change panel type
- Press SET button until PANEL text is yellow and press (-) two times to change it to LPL22W 4L
- Press MENU button to close the Service menu
- Press POWER button to power off your monitor and remove power cable for a minute and plug it in again
Jan 18, 2011 | LG M1962D Monitor
OSD Locked How do I unlock the monitor?
Hold the MENU button for 5 seconds, the 'OSD LOCKED' will appear, to unlock, hold MENU button for 5 seconds, the 'OSD UNLOCKED' will appear. It may not work on ALL LG LCD panels.
Please post back, otherwise check the owner manual.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Sep 09, 2010 | LG 22" FLATRON LCD Monitor
My main home computer whener turned on goes to analog powersaving
LG does not show the 1750 monitor on their web site. It did show some discontinued monitors including a 1752, but there was no information available about them.
Another LG site said to use the far right bottom to auto adjust....for another monitor.
My HP has four buttons, MENU, <, >, and Return (also AUTO). Menu opens the monitor dialog box, with the arrow bottoms shifting through the menu. Select an item with return, then arrow to your selection, menu is also your exit button.
You may have a power saving selection here.
Also check the control panel for the POWER OPTIONS properties. A power scheme selection here will also change the mode of your monitor.
good luck
Feb 18, 2010 | LG Flatron L1750S 17" LCD Monitor
LG W2452T monitor not filling entire screen. How do I get it to work?
Use the menu buttons on the monitor to adjust horizontal and vertical size or press the auto button if it has one.
Jun 10, 2009 | LG Flatron L1718S LCD Monitor
LG 19 in monitor
it would be helpful to know which monitor you have - each one is a little different... basically, you need to press the "menu" button on your monitor, use the arrow buttons (on monitor, not keyboard) to get to the brightness adjustment screen, hit set, then adjust with arrow buttons, and hit set again, then menu to exit.
Jul 14, 2008 | LG L1915S 19" LCD Monitor
LG Flatron L1951S 19" LCD Flat Panel Monitor Logo
66 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
