Question about Canon ImageRUNNER 1670F Copier
Paper jame canon 1670f - Canon ImageRUNNER 1670F Copier
3 Suggested Answers
  • 78 Answers
SOURCE: paper jam in fix unit
canon will tell you the fixing assy. is not to be serviced in the field from experiance I know customers can break these very easily
but if your careful you should be ok
open left hand door
remove front corner panel 2 screws
you need to remove the 2 screws on the black tabs and the 2 large vertical screws 1 front and 1 rear
also there is an earthing screw and the connector block disconnect the 3 connections and remove the unit complete
remove paper fragments
but be carefull this is were most people go wrong and end up damageing the fixing film or thermistor neither of whitch can be repaired
damage these and you will need a new unit
once you have all the paper out reverse the process to refit assy.
good luck
Posted on Sep 13, 2009
joel_baleta
  • 155 Answers
SOURCE: my canon D761 copier does not feed paper. message
paper jam lit when jammed or feeding does not occurs, try cleaning the feed rollers and look if the feed rollers rotates when you copy
Posted on Mar 24, 2010
A4 paper jamed in teh finsher
Go To Below official Canon Printer Page For Your problem, http://forums.usa.canon.com/t5/errors/FilterErrorHandlerPage Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Canon Printer Support
Mar 19, 2014 | Canon Ir 3300 B/w Copier image Runner...
How to fix a paper jam in canon iR1024 copier machine?
My cannon ir 1024 isn't pilling up the paper,how to fix?
Mar 04, 2011 | Canon ImageRUNNER 1670F Copier
I have a Canon iR1024A that is leaving black streaks down side of paper... I have changed the toner.. cleaned out where the toner goes... and changed the drum... nothing changed.. can you help me
If you have changed the drum then probably your fixing film was torn. Check if the black streaks on paper is erasable (not fixed on the paper). Check also for signs of film (gray on one side and brown on the other very thin plastic-like material) falling out from your fixing assembly (if you open the left side cover with caution sign the hot portion area).
Sep 22, 2010 | Canon ImageRUNNER 1670F Copier
My canon D761 copier does not feed paper. message says "paper jamed" but there isno paper jamed.How do I fix this
Mar 19, 2010 | Canon imageCLASS D761 Copier
Paper jam in exit area. How do you remove?
The paper jammed on fixing unit area. Probably the pressure roller is worn-out causing the paper to stick on it rather than sliding the paper out. Remove the fixing unit so that you can remove the paper. Removing the fixing unit needs a lot of skills, I recommend you call the nearest service center for assistance.
Feb 17, 2010 | Canon ImageRUNNER 1670F Copier
I have a serious paper jam that can't be cleared the normal way. I removed the ink cartridge but the paper jam was hidden under a roller that I couldn't get at.
Short of taking it apart, you can usually remove the cartridge and start turning the gears that are visible to move the paper path rollers. (They are hard to turn though...) Make sure you've undone all the paper path clearing doors, hinges, etc. Good luck.
Nov 25, 2009 | Canon ImageRUNNER 1670F Copier
Fax transmission verification
Like Sandman said, the fact you DON'T get an error repport is your confirmation.
Apr 17, 2009 | Canon FAX-L350 Plain Paper Laser
Canon Image runner 1670F will NOT receive faxes
scroll through menu and look for powersave options using keypad and display
Jan 15, 2008 | Canon ImageRUNNER 1670F Copier
Canon ImageRUNNER 1670F Copier Logo
old marine
old marine
