Question about Plantronics Discovery 975 (8164001 P) Bluetooth Headset
How to resolve pairing issue with plantronic discovery 975 with galaxy note3
wb91
  • 126 Answers
SOURCE: My plantronics discovery 975 will
It sounds like you're still in pairing mode (and not paired) if the light is flashing white/red. Take a look at the following link on pairing instructions:
Plantronics Discovery 975 Pairing
If it continued to flash white/red and not pair, you may have a defective unit. Contact where you purchased the unit for a replacement or call Plantronics at 1-800-544-4660 x 5538.
Good Luck from Headsets Direct!
Posted on Apr 18, 2011
  • 823 Answers
SOURCE: Im trying to connect my Plantronics Discovery 975
Two things need to happen in order to pair your headset to your phone. The headset needs to be in pairing mode and the phone needs to be able to see and save the headset as a connection. To make this happen you need to change the settings in the phone to first allow the connection and then put it into the seek and find mode. When the phone is in seek and find mode, you put the blue tooth in discovery mode at the same time and you should be able to pair them. To put your bluetooth in pairing mode, press and hold the power button and turn it off. Then press and hold it to turn it on until the light come on. you should see a blue light that is on for a bit and then turns off. Press the power button again and this time do not release until the headset starts blinking red and blue. when its blinking red and blue release the button and sit it down near you. leave it on and blinking until finished. now follow the instructions listed below to turn the bluetooth option on and get your phone in discovery mode:
First select a 16 passcode for remote sim card access.
Press options - then new paired device and the phone will search for bluetooth devices.
if your phone picks up other bluetooth devices before it finds yours, press "more devices" until you see the name of your headset.
when the phone finds your headset - select it and press yes for auto connection.
Then select set as authorized and you are done!
You can find these instructions on this link:
http://www.nokiausa.com/get-support-and-software/product-support/e63-support/guides
Posted on Apr 20, 2011
wb91
  • 126 Answers
SOURCE: plantronics discovery 975 won't turn
Just to make sure you are turning off the earpiece correctly:
Press the call control button for 4 seconds. It will glows red. Then you will hear 4 descending tones. If this does not work I would suggest taking it back to where you purchased it from and have it replaced, the headset has a one year warranty.
Good luck from Headsets Direct - 800-914-7996.
Posted on Aug 19, 2011
wb91
  • 126 Answers
SOURCE: How to setting plantronics discovery 975
Plantronics Discovery 975 settings:
Not sure exactly what you are specifically asking, however here is a link for the 975 user guide. The 975 user guide will tell you all about the settings and how to put it into pairing mode to connect to your cell phone as well.
http://www.headsetsdirect.com/pdf/discovery975_user_guide_en.pdf
HDI Headsets
  • 537 Answers
SOURCE: I have my plantronics discovery 975 paired to my
  1. Make sure you are using the latest version of Skype.
  2. Make sure that Bluetooth works on your computer. You can refer to your computer manufacturer's documentation or website for details on how to set up Bluetooth on your computer. You want to ensure that the Bluetooth software and drivers (known as the Bluetooth stack) on your computer supports the Headset Profile (HSP). It's recommended that you download and install the latest drivers for your Bluetooth stack.
  3. Pair your Bluetooth device with your computer. How you do this will depend on both the Bluetooth stack on your computer, and the Bluetooth device you are using.
  4. Make the Bluetooth device your Skype audio device:
  • Sign in to Skype and in the Tools menu, select Options...
  • Under Audio settings, select your Bluetooth device from the Microphone, Speakers and Ringing drop-down list.
  • Remember that not all Bluetooth headset features may be available when making a call with Skype. For example, whether the buttons on your headset function correctly depends on your Bluetooth stack.
Good luck from Headsets Direct!
Posted on Aug 30, 2011
Cant listen to music on my 975
The Plantronics Discovery 975 Bluetooth headset does not supports Advanced Audio Distribution (A2DP) and you need this Bluetooth profile to be able to stream music between two Bluetooth devices. The device you are streaming music from (example: cell phone) to the headset must also support Advanced Audio Distribution (A2DP).
Dec 07, 2011 | Plantronics Discovery 975 (8164001 P)...
Aug 19, 2011 | Plantronics Discovery 975 (8164001 P)...
Plantronics discovery 975 won't turn off nor pair with phone...
Aug 05, 2011 | Plantronics Discovery 975 (8164001 P)...
Plantronics Discovery 975 - just stopped working - will not turn off or on - nothing happens when button is depressed
Sounds like you have a defective headset. You'll need to return it to your retailer, or call Plantronics at 800-544-4660 x5538 for warranty replacement. If it's past the warranty period check out what's new at the following link: bluetooth headsets.
Jul 08, 2011 | Plantronics Discovery 975 (8164001 P)...
My plantronics discovery 975 will not connect to my phone. it is paired. the indicator light is flashing White then Red, any ideas
Apr 18, 2011 | Plantronics Radio Communications
How do you do a factory reset on a plantronics 975 bluetooth?
After posting the above I got the answer. You press the answer button down it will flash white keep holding it down until it goes back and forth red white red white. This disconnects previous user and their password and now you can pair it to your phone.
Feb 11, 2011 | Plantronics Discovery 975 (8164001 P)...
How to connect plantronics 330 bluetooth headset with my iphone 4
When joining (or pairing) a Plantronics bluetooth headset to another device a lot depends on the other device. Assuming that you know the necessary steps of your phone or PC for connecting a bluetooth device, all Plantronics headsets pretty much follow a set pairing procedure for connectivity. This one is for the Discovery 975:
1 Turn on the Bluetooth feature on your phone.
2 Turn the earpiece on. Press and hold the call control button until the indicator flashes red/white.
3 Use the commands on your phone to locate and select your earpiece. 9xx Plantronics.
4 If prompted for the PIN code or Passkey, enter 0000.
Pairing is successful when the indicator on your earpiece flashes white.
Note If your phone supports Secure Simple Pairing (SSP), you will not need to enter a PIN code or Passkey.
Jul 20, 2010 | Plantronics Explorer 330 Headset
How to connect my Nokia E71 with Plantronics 330?
Mar 22, 2010 | Plantronics Explorer 330 Headset
Need help pairing
Feb 28, 2010 | Plantronics Explorer 330 Headset
Plantronics Discovery 975 (8164001 P) Bluetooth Headset Logo
26 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
