Question about Freezers
Zanussi zfu228wo not freezing stays warm
Top shel and top door shelfs are not freezing food solid ... Bottom freezes , all food on top portion thaws
you may have ab ad fan inside the cooler and all of the cold air is staying at the bottom. Also there may be bad insulation at the top and there may be warm air up there.
Jan 11, 2016 | Amana 20.1 cu. ft. Frost Free Upright...
Why does the red light on my VF70 freeze r stay on all the time?
Warning light (red)
If the temperature warning light ? lights up, it indicates that the temperature within the freezer has reached a level where the safe food storage is no longer ensured. When the freezer is first switched on, the warning light will stay on until the temperature has dropped to a safe level for the storage of frozen food.
Dado
May 05, 2014 | Zanussi 3.53 cu. ft. / 100 liter Upright...
Zanussi freezer Zut 6246. Superfreeze button won't go off
Probably is switch for fast freezing mechanically defective.
Dado
Apr 07, 2014 | Zanussi Freezers
What indicate liters in freeze?
The liters indicate the storage capacity. The more liters there are, the higher the strage capacity.
Jan 30, 2013 | Zanussi 11 cu. ft. / 311 liter Chest...
Fridge warm. lights up. turned it off for a bit then back on any clues to get it back to cold. freezer waming too
Do you hear the compressor running? If so you may have a bad defrost timer, causing the evaporator to freeze up, and therefore your poor cooling. If you do not hear the compressor coming on then it could still be a defrost timer issue (stuck in defrost) or it could be a more serious problem that will need to be tackled with a voltmeter and a clamp on amp meter. (checking @ compressor)
Hope this helps
Oct 05, 2009 | Zanussi 5.30 cu. ft. / 150 liter Upright...
Freezer not freezing!
try plugging the electric cord into a receptical
Feb 18, 2009 | Zanussi 5.76 cu. ft. / 163 liter Chest...
Zanussi ZX 57/3 fridge and freezer not working
Hi . Most freezers with the condenser coils at the back do not work when the temperature where it is placed gets below (( 5 degree c ))?? IE in a garage if it is freezing weather outside. One solution is somehow to keep the condenser compartment warm. Check the makers website. for what they say about it
Jan 10, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Not freezing/cooling
Sorry but this sounds serious to me. If you have no cooling effect whatsoever and the compressor runs that means it's either not pumping or the refrigerant has leaked out. This is one you may have to call a tech out for. good luck
Dec 11, 2008 | Freezers
Warning alarm and light
it will do that till temp is reached
Oct 19, 2008 | Zanussi 3.53 cu. ft. / 100 liter Upright...
Freezers Logo
70 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
