Question about Canon BJC 80 InkJet Printer
I want to be able to use cannnon bjc-80 with my Sony Vista. I bought a converson cable- USB to Parallel. It was a DYNEX . It wouldnot work, I am going to bring this product back.
  • 221 Answers
Yes You need proper USB/Paralel cable in order to use ur printer.
But good luck anyway
Posted on Jun 22, 2009
How to print from Window Vista to Canon BJC80 printer using USB to Parallel cable
Helen, is the printer correctly installed in laptop? Check if shows under Printers and devices. If not, install and show it as default. Make sure your usb connections are ok.
Mar 19, 2014 | Canon BJC 80 InkJet Printer
Cannot find vista drivers for my canon bjc-80, any help would be great.
Now that is a tall order. Finding drivers for a bubble jet printer. My best bet is that you'll need to contact the manufacturer of the printer and ask them if any such updates are available.
Vista do however have a large driver database.
Here is a link. Download and try. Do hope this help.
http://www.softwaredriverdownload.com/canon_bjc_80_printer_driver_for_windows_xpvista.html
Aug 17, 2009 | Canon BJC 80 InkJet Printer
BJC 80 w/ Vista OS prints 1/2 page and goes to error mode.
Purchase a PCMCIA parallel port card. That's a PC Card parallel port adapter. It provides a native parallel port to laptops that do not have one built in. Works perfectly in ALL cases, even with the scanner cartridge.
Jun 09, 2009 | Canon BJC 80 InkJet Printer
I have a canon bjc 80 connected via usb to acer laptop with vista on says hardware successfully installed & sounds like it is printing but will not feed paper or print !! have not used a disc to install...
Purchase a PCMCIA parallel port adapter. the USB to parallel adapters are a pain to set up and are flakey at best. The PC card adapter provides a native parallel port to laptops without one, and works perfectly in ALL cases, even with the scanner cartridge.
Feb 19, 2009 | Canon BJC 80 InkJet Printer
Canon BJC 80 New Cable Required
You Can Get Them At Radio Shack, Circuit City Or Best Buy Maybe Even Wal-mart
Jan 07, 2009 | Canon BJC 80 InkJet Printer
What does disabling bidirectional support mean
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} USB to Parallel conversion requires translation by XP and Vista's 'hardware interleave' software as well as the USB device manufacturers driver. The software package just doesn't work well with older peripherals that use legacy parallel or serial com ports. Too many sloppy layers.
THE BEST WAY to add an LPT printer port to your laptop is to use a PCMCIA to Parallel adapter card.
The PC Card slot provides access to the laptop's data bus, and the PC Card adapter easily sets up as a native LPT port within almost any OS.
There is no delay, or connection problems as I've seen in so many complaints about USB to Parallel or Legacy Serial adapters. Printing is Instant.
PCMCIA is a mature standard, and works seamlessly with XP and Vista, and almost any other OS.
PARALLEL is the old standard fast data protocol. IEEE 1284 ECP mode up to 1.5 Mbps.
The BJC-80 and the BJC-85 have the same print speed. The BJC-85 just added USB.
INFRARED is ver 1.0 on the BJC-80, and printing is a bit slower at 115.2 kbps. Even the BJC-85 with its higher IRDA transfer rating and a laptop's built-in IR port, the XP print spooler has problems with it, and can hang if printing more than one page, and especially with more than one document. It will not scan.
I use IR for printing single pages only with either the BJC-80 or BJC-85.
USB to IRDA adapters work fine, and are less expensive $5-6 than
PCMCIA to Parallel adapters, $20-25.
I have tested and used several PCMCIA adapters from different manufacturers, and they all work perfectly as a hot-pluggable, instant LPT and/or Legacy Serial port for my laptops.
TIPS:
After installing the PC Card driver, check Device Manager for the LPT port number.
Install the printer manually from the list of printers, and select the proper LPT port.
Most laptops have two PCMCIA slots. If you change slots, the adapter card driver may reinstall, and assign the next available LPT port, LPT2.
To scan with the BJC-80, you must have an LPT port.
The PC Card adapter also allows the use of the IS-12 scanner cartridge within XP or Vista.
Within Vista, set the Canon ISScan software to run in Windows 98 compatibility mode, to allow use of the TWAIN driver.
Jun 12, 2008 | Canon BJC 80 InkJet Printer
Canon BJC 2000 question-1284 to usb
TIPS:
Jun 05, 2008 | Canon BJC 80 InkJet Printer
BJC 80 Won't Print
Try disable bidirectional support
Jun 02, 2008 | Canon BJC 80 InkJet Printer
Time consuming
Try installing the latest driver: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=230&modelid=7998
Aug 23, 2007 | Canon BJC 80 InkJet Printer
Canon BJC 80 InkJet Printer Logo
192 people viewed this question
old marine
old marine
