Lamona HJA 8704
How do you open the washing machine door when the button is broken? The button broke when I tried to open the door?
4 Suggested Answers
  • 6277 Answers
SOURCE: Lamona Washing Machine HJA 8514 Half way through a
(no promises but try this!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 27, 2011
SOURCE: My Lamona integrated washing machine
Hi Guys,
My Lamona washing machine is also stuck on rapid wash? Dis you get it resolved?
Kind Regards
Posted on Sep 02, 2011
SOURCE: I was using my Lamona
Hi Karl
Did you get this issue resolved as I have the same problem?
Cheers
Posted on Oct 02, 2011
Handle broke off
How to open a washing machine door that won't ... - YouTube
? 3:57
https://www.youtube.com/watch?v=-65_eoT6zuk
Aug 22, 2013 - Uploaded by how-2-repair.com
1 The washing machine door handle may have broken. ... 3 The electronic door lock called an interlock ...
Opening a locked washing machine door - YouTube
? 1:30
https://www.youtube.com/watch?v=gSF4JS2B_U0
Feb 25, 2012 - Uploaded by ScottStorm1
How to open a locked washing machine door when the handle / catch is ... How to fix a washing machine door ...
How to open a broken washing machine door. - YouTube
? 0:25
https://www.youtube.com/watch?v=UCJPkc_dTCE
Feb 26, 2013 - Uploaded by Kim Degerth
How to open a broken washing machine door. .... How awashing machine door lock works, how to test ...
How to Fix Washer With A Lid Or Door That Won't Op
Oct 07, 2015 | Splendide 2100 Vented Washer-Dryer
The washing machine has stopped midcycle and the start button is flashing red do you have any ideas of what may be causing this?
try to cancel it out and start again, if it won't cancel machine is telling you that something like belt broken or door open, etc.
Sep 22, 2015 | Zanussi Washing Machine Door Seal...
Lamona hja 8514
You have an internal pump which is not accessible without uninstalling the appliance, however instead of using drain block have you tried a proper appliance cleaner and cleaning the connection under the sink as this is where most smells come from and not the machine themselves
Apr 07, 2014 | Washing Machines
The kenmore elite smart wash quiet pak 9 I opened the door and threw something else in and now a light is on thar says controls locked and it wont do anything
There should be a button on the control panel that says "open door" you need to push that button and wait for the washer to shut off before you open the door. Try pushing that button to see if that resets. My guess is that you broke the safety latch when you opened the door and it will need repair.
Mar 10, 2014 | Kenmore Washing Machines
Door handle broke
This is not an identical one but is another LG that has the same latch setup. Hope these pics help.
Mar 07, 2012 | LG WD-16115FD Front Load Washer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
