Question about Margaritaville Frozen Concoction (DM1000) Blender
My DM1000 wont shave ice, I checked the kill switch on it, seems fine, everything else works.
Where are the kill switch for the Margaritaville Concoction (DM1000)
There is no kill switch. There is a power on/off switch, which is the far left switch on the front panel.
Jun 23, 2014 | Margaritaville Frozen Concoction (DM1000)...
Cant take apart ice crusher portion of unit
The Ice Reservoir has a release botton at the back of the reservoir. The button must be pushed down at which time you can lift from the back and remove the ice reservoir. You can download the operating instructions for your machine here:
http://www.jardenstore.com/manuals/MANUALS/DM1000-000-000_43_64821634.PDF
Dec 22, 2011 | Margaritaville Frozen Concoction (DM1000)...
My margaritaville shaves too much ice into the blender, so it doesn't mix.
When mine did that I just put in less ice the next time and I experimented to see how much liquid to add. Once I did the 2nd and 3rd batches of drinks I got the hang of it.
Sep 18, 2010 | Margaritaville Frozen Concoction (DM1000)...
A red light is on my margaritaville machine and have to manually hold switch to shave ice. what can I do to fix?
As soon as I turn my tahiti on I get a red flashing start button is this normal? And I also have to hold the button to mix?.
Aug 02, 2009 | Margaritaville Frozen Concoction (DM1000)...
Can not get Margaritaville blender to start
look for rocker switch left side of machine near bottom
Jun 30, 2009 | Margaritaville Frozen Concoction (DM1000)...
Plastic pieces on glass jar and base are worn out and shaved down
I did the same thing. Order parts at thegourmetdepotco.com -- This problem is caused when you put the rubber gasket underneath the blade instead of above it. This causes two problems: 1. It lifts the teeth on the jar away from the teeth on the drive gear, which can grind down and break off the teeth, and 2. If the drive gear contacts the rubber gasket, it will melt the rim of the drive gear. In the future, to reassemble the jar after cleaning, first put the rubber gasket on the jar, then the blade, lastly screw on the base ring.
Apr 19, 2009 | Margaritaville Frozen Concoction (DM1000)...
Need help
the manufacturer - their number is: 1-877-689-2737
You can also send an e-mail through their website if you prefer:
http://www.margaritavillecargo.com/CustomerService.aspx
-Tha Mp3 Doctor
Jan 14, 2009 | Margaritaville Frozen Concoction (DM1000)...
Margaritaville Frozen Concoction - Ice shaver has stopped turning
On my machine (DM1000) there is a kill switch on the top & back of the ice reservoir. If that gets broken/misaligned the shaver will not activate.
Jul 22, 2008 | Margaritaville Frozen Concoction (DM1000)...
Margaritaville Frozen Concoction (DM1000) Blender Logo
Top Margaritaville Blenders Experts
john h
Tom Chichester
Are you a Margaritaville Blender Expert? Answer questions, earn points and help others
