Question about Fuji FinePix Z10fd Digital Camera
Fuji FinePix z10fd does not come up as removable disk on PC
I cannot make my Fuji FinePix camera come up as a removable disk on my PC, I erased some pics from my SD card and need to recover them but the camera only shows up as a camera and I need it set as mass media, any ideas?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Fuji Master
  • 102,366 Answers
The camera cannot be used as a card reader. You'll need an actual card reader to write to the card. Yes, it's confusing. You can read the card without a card reader, but you need a card reader to write to the card.
Posted on Dec 28, 2012
  • kakima Dec 28, 2012
SOURCE: Fuji FinePix xD picture card - Card not Initialized
I am having the same problem! HELP
Posted on Jan 17, 2008
sandrew
  • 2961 Answers
SOURCE: no software for fuji finepix
go to the link below for the driver, you dont need software as you can explore the camera in my computer and copy then paste the photos, but windows may come up with picture viewer when you connect the cam up to the pc
http://www.fujifilm.co.uk/consumer/digital/digital-cameras/legacy-cameras/finepix-a204-zoom/support
Posted on Aug 29, 2008
dlundmark
  • 797 Answers
SOURCE: my fuji finepix z10fd won't turn on. I bought a
When ever any kind of unit, camera or other wise will not turn on, then there are all kinds of problems which could cause this. It could be in the battery circuit with something wrong or disconnected. It could be in the switch to turn on the unit. There also could be a number of other things which could be at fault all of which could cause the camera not to turn on.
If there is some thing which happened in the past such as an impact, water getting inside the camera, or from being dropped, all of which could cause trouble.
My suggestion is to sell it on a site such as Ebay as parts, or have it looked at (if it is worth it) by a repairman.
Posted on Sep 01, 2009
Testimonial: "Thanks so much :)"
SOURCE: Fuji FinePix S1 Pro Digital.
camera displaying FEE
Posted on Mar 08, 2010
  • 241 Answers
SOURCE: Replacing LDC screen on Fuji Z10FD camera
Probably, yes.
Remove the 2 screws on the side,
Remove the 3 screws in the buttom. (2 of which are tri-wing)
Remove the 2 screws in the battery compartment.
Flip out the chrome side (from the front backwards)
Remove the 2 screws underneath the chrome side.
Turn the camera upside down. You can now flip the backcover down (gently lift the cover, both on the mid by the tripd hole and on the side, where the crome plate was) Watch out for the USB connector.
Gently lift the broken LCD out. You need to release (flip up) the tiny white lock on the connector to release the ribbon.
Assembly same procedure, but backwards.
Beware of the flash components. The can give a nasty electrical chock.
Posted on May 21, 2010
Got a fujifilm finepix z, and i've lost the cable to connect it to my computer. Just bought a card reader but when I plug the sd card into it it says format disk. Will formatting cause me to loose the...
Yes, formatting will erase your pictures. If I'm not mistaen, this camera uses a standard USB Mini port, you can purchase one at any computer or electronics store.
Mar 21, 2011 | Fuji FinePix Z10fd Digital Camera
I was taking pics then closed camera then reopened and it say card not initialized
The card may have an error on it. Try reformatting it from the camera setup menu. This will erase ALL pictures on the card.
Jul 02, 2010 | Fuji FinePix Z10fd Digital Camera
Lost my software CD of my Fuji Finepix Z10fd, how ...
You don't need any software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
May 20, 2010 | Fuji FinePix Z10fd Digital Camera
Probably, yes.
May 21, 2010 | Fuji FinePix Z10fd Digital Camera
Camera wont connect to computer anymore, use to but now not working. 1st says its in use try again later and then says not connected check cables..
Did you try uninstalling program by going to Control Panel > Add or Remove Programs > look for Fuji FinePix and click on Remove, then re-install with CD Disc provided with camera.
Jul 26, 2009 | Fuji FinePix Z10fd Digital Camera
My picyures wont load up,the camera is properly connected 2 da lapyop and its installed correctly but the computer does not show it
If your PC doesn't show it then you unplug it and plug it again. If it's recognized by your PC then it should appear in the "My Computer" hard disk drives.
May 04, 2009 | Fuji FinePix Z10fd Digital Camera
Battery problems
I've removed several using a pair of "duck-billed" needle-nose pliers. They're quite common and will allow you to grab the battery without damaging it or the camera body.
May 16, 2008 | Fuji FinePix Z10fd Digital Camera
Camera will not come on
try to use another battery and if it does not work please contact the manufacturer to get the camera replaced.
May 07, 2008 | Fuji FinePix Z10fd Digital Camera
Fuji FinePix Z10fd Digital Camera Logo
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
