Question about Cell Phones
Gigaset siemens ac650
Why isn't our phone working after we left it? We left the phone for 2 and half months unused (while abroad). Now we can't get the handset to work. The charging light has been on and we've left it for over two days, but when we lift the handset there is no dialing tone at all and nothing appears on the 'screen'. Our internet is plugged into the same socket and that is working fine. What do you suggest?
  • 201 Answers
SOURCE: cordless phone keeps reading, "lift handset"
This would normally happen when the cordless handset was still in the charger stand. Are you saying it will still tell you to lift the handset after it's removed from the charger stand or base? I would not waste money buying a new battery as it is most likely not the problem but if you have more than one handset you should try swapping batteries. Removing and re-inserting the battery may reset the phone and clear up the problem as well.
Posted on Jul 07, 2007
NickBeamAA
  • 53 Answers
SOURCE: Screen went blank
There is something you can try. Using a Torx 6 driver, remove the two screws located beneath the battery. Gently pry the plastic cover loose. There will be a flex cable connecting it to the other portion of the phone. Gently disconnect it. Using 99.5% isopropyl alcohol and a soft bristled brush clean the connectors on both the cable and the circuit board. Reseat the connector and reassemble the phone. If this does not work the flex cable or LCD may need to be replaced.
Posted on Sep 09, 2007
CORDLESSGURU
  • 106 Answers
SOURCE: Problem Siemens Gigaset 4000 and 4200
If you had a storm, and the only handset that works shows line in use, then your base has gone bad and needs repair. The reason the phones are flashing base 1 or something to that effect is because they don't see the base anymore, which typically means no phones will see your base, so its odd that one phone is actually seeing the base. Either way, you can try re-registering the phones to the base, but if you get the line in use after they register (if they will register), then your base is bad. If they won't register, your base is bad. For additional assistance you can go to www.cordlessrepair.com
Posted on Jun 16, 2008
SOURCE: phone wont turn on
Battery is so low it won't turn on. Leave on charger for a half hour or so and it will turn on again. Replacing the battery worked for me!
Posted on Jul 18, 2008
SOURCE: I have a siemens gigaset
Try a harware reset! dont worry this will not delete anything on your handset. it is a simple procedure:
while the phone is on take out the battery and then the sim
then insert the battery by itself and power it up.
It should ask to insert a sim or something along those line.
when it does take the battery out again while the phone is on.
put it all back together and power the phone up again.
If this does not work.
Try MnuL ROm in network settings. search manualy and select a different network to what you are on and then do the same and go back to your service provider. then reset back to automatic.
if that does not work there is one more thing.
if the handset is 3G try setting to GSM mode only.
Posted on Sep 30, 2008
I have a Siemens Gigaset A420 A Trio obviously three handsets.
Chargeable and non-rechargeable batteries are not interchangeable.
Aug 02, 2016 | Siemens Gigaset A420a Trio Dect Cordless...
Siemens Gigaset A260 cordless phone fail to register
We've tried to register the Siemens A260 handset to the base but it continues to flash "Base".. and does not work.
Jun 19, 2009 | Siemens Gigaset 8825 Cordless Phone
Siemens gigaset 2420 two line phone drops calls
dump the memory by deleting your mailbox and your call log-
Feb 15, 2009 | Siemens Gigaset 2420 Cordless Phone
I have a siemens gigaset S455 i had to take the phone to a new house that im going to rent next month to find out the new phone number back home i need to register the handsets (x2) and cant find the...
unplug the base and press the register button. (it's the round one to the left of the minus button) holding the register button plug the base in and continue to hold the register button for at least two seconds. you should hear a beep. the pin has been reset to 0000.
Dec 07, 2008 | Siemens Gigaset S455 Cordless Phone
You did get spiked from the power company, and your system needs repair. Go to www.cordlessrepair.com for help.
Jun 23, 2008 | Siemens Gigaset 4000 Phone
Jun 15, 2008 | Lands Phones
Phones will not register
Try this:
Pick a handheld, press Menu - H/set settings - Reg Handset - Select Base 1, enter 0000 as password. Now on the bottom of the base station press and hold the Register button in for about 10 seconds or until the h/set beeps.
Geno
Jan 15, 2008 | Siemens Gigaset 4215 Cordless Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
