Question about Exabyte Computers & Internet
Sense key error = 4 - Exabyte Computers & Internet
What doe error code CE signify????????..
4. Troubleshooting
4-2
4-2. Service Inspection Mode
- Press the Delay Start + Normal + Power keys at the same time for two seconds to enter Service Inspection Mode.
- "ALL" is displayed for the first three (3) seconds and then "t1" is displayed.
- You can change the mode by pressing the Normal key. Each time the Normal key is pressed, the mode changes in the order of t1 ? t2 ? t3 ? t4 ? t5 ? t6 ? t7 ? t8.
- If you want to activate a mode while operating the dishwasher, the door must be closed (The Door switches are ON.)
- If an "oE", "LE" or "tE1" error occur, make sure to enter Service Inspection Mode after resolving it.
- Service Inspection Mode is described in the following table.
Mode Related parts Symptoms Note
t1
Inlet Valve
Flow Meter
Low Level Sensor
4E
9E
If you press the Delay Start key, water is drained for 45 seconds and then the water supply starts.
If the pulse count is more than 660, change the mode.
Make sure to change the mode when the pulse count is more than 660 in t1 mode.
t2 Circulation Motor A nozzle does not inject
water.
1. Press the Delay Start key to start or stop the Circulation Motor.
2. If a low water level is detected, water is supplied again and the operation continues.
t3
Circulation Motor
Heater
Thermistor
HE
1. Press the Delay Start key to start or stop the heater and the circulation Motor.
2. If a low water level is sensed, water is supplied again and the operation continues.
3. The current temperature is shown on the display.
4. If the water temperature is more than 70?C, the Heater does not operate.
t4 Fan Motor The Fan Motor does not
operate. Press the Delay Start key to start or stop the Fan Motor.
t5 Drain Pump
Low Level Sensor 5E 1. Press the Delay Start key to start the 2 parts.
2. When draining is finished, "t5" is blinking on the Display LED.
t6 Low Level Sensor
When the Micro Switch
is turned on/off, there is
no change on the display
or a symbol other than
On/OFF is displayed.
1. MICRO SWITCH On
? The sensing state is displayed as 'On' on the 88 segment display.
2. MICRO SWITCH Off
? The sensing state is displayed as 'OFF' on the 88 segment display.
t7 Thermistor There is no change in the
water temperature. The current temperature is displayed.
t8
Half Load Position of
Distributor Motor
Micro Switch
(DMR77 Model)
PE
1. If you press the Delay Start key, the parts operate just once.
2. There is no stop function.
3. While the Distributor Motor is operating, its sensing state is displayed as On/OFF on the 88 segment display.
4. When the Distributor Motor stops, the sensing state (On/OFF) of the Micro Switch is displayed.
Caution
If it has the power problem, you must check the FUSE first.
This dishwasher has the FUSE upon the Base. Refer to the 4-10 page.
Try these steps to solve your error there is no CE code listed in the manual
Dec 12, 2010 | Samsung DMR78AHS Builtin Dishwasher
I am getting a CE error, what does that mean? Bill
4. Troubleshooting
4-2
- You can change the mode by pressing the Normal key. Each time the Normal key is pressed, the mode changes in the order of t1 → t2 → t3 → t4 → t5 → t6 → t7 → t8.
t1
Inlet Valve
Flow Meter
Low Level Sensor
4E
9E
water.
t3
Circulation Motor
Heater
Thermistor
HE
4. If the water temperature is more than 70ºC, the Heater does not operate.
t5 Drain Pump
t6 Low Level Sensor
1. MICRO SWITCH On
→ The sensing state is displayed as 'On' on the 88 segment display.
2. MICRO SWITCH Off
→ The sensing state is displayed as 'OFF' on the 88 segment display.
t8
Distributor Motor
Micro Switch
(DMR77 Model)
PE
Caution
This dishwasher has the FUSE upon the Base. Refer to the 4-10 page.TRY THESE STEPS AND SEE WHAT HAPPENS THERE IS NO CE FAULT CODE LISTED IN THE MANUAL
T5 error code comes in my amana dryer ned 7200tw
That is actually a Ts error.
Thermistor Short Sensed
The Thermistor resistance is very low.
Check for:
- Clogged lint screen.
- Restricted vent system.
- Check Thermistor resistance.
Thermistor is Item #27 HERE
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 06, 2010 | Amana NED7200TW Electric Dryer
Error 306
Error 306 is the 4 wire measurement error that happens when you try to reassign a channel needed for a 4 wire measurement to something else. Two measurement channels are required to make a 4-wire Ohms measurement, one for source and another for sense. The pairs are preconfigured by the 34970A. If channel x01 is declared to be a 4-wire measurement channel, the 34970A will assign channel x11 in the same 34901A module to be the sense channel for that measurement. In the 34902A module, channel x01 is paired with x09, where x is the slot identifier number. Error 306 only occurs as a result of user generated programming. Benchlink Datalogger and front panel operation block the user from reassigning a 4-wire configured sense channel.
Aug 13, 2009 | Dell Office Equipment & Supplies
The drive reported an error: sense key-medium error sense ode= 0x0c write error iomega 48x24x48x cd/rw usb burner
this is almost certainly a dirty lens on the writer. clean it with a lens cleaning disk.
May 07, 2009 | Iomega (32885) CD-RW Burner
E8 error code
8E - OVER CURRENT ERROR
IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
IPM: Integrated power module. The IPM controls the motor.
If the fault (low signal) happens to be sensed even once during the washing/rinsing stage, the motor stops immediately. However, during the dehydrating stage the signal is to be sensed, when the number of signals reads more than 6 per 500ms during the Washing or Rinsing cycle action.
If the motor stops working, in one direction ten times, "8E" Error is displayed.
During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error "8E" is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power Switch OFF can clear the overload error.
May 02, 2009 | Washing Machines
Burn fail or cd skip
Kind of sounds that way. They are pretty inexpensive now days, and simple to install.
Good luck
Mar 17, 2009 | Gateway M680X PC Notebook
TDK CD-RW Burner Sense Key Error
You may try this dvd creator for mac, I always use it to burn music and dvd, it works pretty well for me
http://macdvdcreator.mac-dvd.com
Mar 28, 2008 | Computers & Internet
DVD write problem and hardware test error code
I hope this works for you it did for me when I updated all my firmware.
http://docs.info.apple.com/article.html?artnum=88275
Jan 13, 2008 | Apple Power Mac G5 Desktop
Computers & Internet Logo
Top Exabyte Computers & Internet Experts
David Payne
David Payne
Are you an Exabyte Computer and Internet Expert? Answer questions, earn points and help others
