On my a/c fujitsu asu12c1, the condenser need too much power and the breaker jump. the contractor told me than i need part no 9703433023. I need this part at lower price as possible. Can I do something else Where I casn buy the part
  • rene_turgeon Jun 22, 2009
    The solution work for me.
    merci
    Brigadier General:
  • 3,917 Answers
After doing a detailed R & D on various venders sites the best deal I got is of 141$.
Part Number-K9703433023
Model No-MW12C1E/ASU12C1
Discription -CONTROLLER PCB ASSY
Price -$ 141.68
Note : We have checked the authenticity of the parts as well. As its from Fijitsu US there is no worries. Few sites offered less price but could not depend on their part.
Fujitsu 1-901-259-5790 http://www.fujitsu.com / intlfujitsu@fujitsupc.com
Thanks for contacting Fixya
Posted on Jun 22, 2009
I shut the power off to a smart meter that was on a house I was remodeling. When I restored power to the meter the power in the house stayed off why
Two things jump to mind.
The contractors turned of the main breaker in the fuse box.
The utility company doesn't have you registered with them and they have stopped power after the last occupants left. When you turned the power off the utility company saw there was no demand so the place was empty.
Jan 27, 2016 | Computers & Internet
Condenser fan on heat pump does not turn off
If it is just the condenser fan that means you have a fan relay that has welded shut. Turn power off to your unit and trace the wires from your condenser fan back into the control panel at the unit. You'll have 3 wires going to it. 2 go to the run capacitor and one goes to the fan relay. The one that goes to the fan relay is the part that needs to be replaced. If you have no fan relay and it goes to the main contractor, half of your main contractor is welded shut and will need to be replaced.
Sep 18, 2014 | Carrier 52PQ-515---3 Premier Series Heat...
Condensing unit will not turn on the evaporator fun is blowing 92 degrees
Check your circuit breakers and or fuses to make sure you have power to the condenser. Also verify thermostat is in the cooling mode.
Oct 02, 2013 | Fujitsu ASU18CL Halycon Wall Mounted Air...
Roof top air conditioner or condenser fan with not come on
Now it all depends weather you have a call for cooling, now assuming you do and the compresser is running I would theck the contractor to see if it is closing and all of the contacts are still there. If it is not closing then you have to check for the power supply to the coil usuall 24v, if the power is there then use an ohm meter to check the continuity o. The coil on the contractor. If it reads OL then it is shot and replace the contractor. If the contractor is pulled in then check for power on both sides of the contractor, if power tree then access the motor after turning the power off, if the motor is hot then it is probubally done fore, you again can check it with your ohm meter. If the motor reads OL she is done fore and needs to be replaced. Good luck
Sep 08, 2012 | Coleman Mach 15 Air Conditioner
I have a Fujitsu ASU24CL1 and after a loss of power we now have no A/C. Fan works but the red and green lights flash 5 times then go off for a short time then flashes again ?
Seems like a problem with ur condenser power wiring, check diconnect, line from breaker should be in line and line goin to cond should be on load
Jul 01, 2012 | Fujitsu 24C1 Air Conditioner
Recently replaced entire central a/c - Removed 2,500 ton Rheem condenser - Unit is approx. 2-1/2 to 3 year old - 13 Seer - Interested in selling unit...Who made be interested in purchasing??? What would...
Hi, 2,500 ton unit would be the size of a 15,000sq.foot warehouse! I think you mean a 2 1/2 ton Rheem condenser. You could run an add under Craigs list.com, and if the unit is in good shape, I would ask no more then $600 for it. As a Contractor, I can get them anytime new for around $660.00. If you can get $500 for it jump on it. Best of luck to you,
Shastalaker7
A/C Contractor
Jul 26, 2011 | Heating & Cooling
No 24 voltage to thermostate & no fan no furnace no condenser works.
Hi, if you have no 24 volts to stat, and nothing is working, its not the transformer, you have lost the main power to the system. Check the main breaker as it has tripped on you. Shut it off hard, and flip it back on hard to reset it. It has to be a main power failure to cause all to stop working. Check fuses at the condenser box also. It has to be the main though, since the indoor unit is off also. Believe me, this is your problem.
Shastalaker7
A/C, and Heating Contractor
Please rate me on this :))
Nov 23, 2010 | Heating & Cooling
Unit will not start up evaperator fan runs
Hi, if your indoor unit is running and you have high voltage to the outdoor unit as the compressor runs, I would check the control wires at the indoor unit, coming from the outdoor unit, and from the thermostat terminals to see if the condenser is wired correctly. I'm not sure what relay you are jumping out to get the compressor to run, and no fan, but if you look at the contactor where your high voltage leads connect, you can energize the contactor by pushing down on the plastic part of the contacts and the outdoor unit fan and all will start. Carefully, use a insulated screwdriver, or I have pushed them down with my finger to see, but be careful! You do have high voltage there or the compressor wouldn't have come on. If all runs when you do this, the thermostat control wires to the contactor have no 24 volt control voltage to it. Check your red and yellow wire connections. If you have a meter, check across the 2- for 24 volts. If you have no low voltage, this is your problem. Go to your indoor control section. If this unit has a circuit control board, look for a plug in type fuse like you would find in your car, a 3 to 5 amp fuse. Make sure its not blown. If the led light is on, it will be good. You have lost the low 24 volt power to run the outdoor unit. Check the wiring there, Red and Yellow. Make sure they are terminated. If none of this helps you or your not at ease doing these checks, call out the contractor and tell them that the outdoor unit will not run if it is new and just installed. They should have done a start up on it. Check the contactor first by pushing it down, it will spark but don't jump as it may scare you some. If all runs, check everything I have told you and you should find the problem. If you have any questions, contact me through this site by my user name, shastalaker7. Keep me posted.
Sincerely,
Shastalaker7
Jun 16, 2010 | Fujitsu 24C1 Air Conditioner
Fujitsu ASU12C1 is freezing up
unit is freezing up because it either has too much freon or not enough. the pressure should be checked on both the low and high sides and corrected.
Jun 13, 2009 | EMI EHW 18000 Air Conditioner
Heating & Cooling Logo
240 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
